NUMEGO Switch
Turbo4V
Vehicle Information: 2000 Mustang
Twin Turbo 4V
PTP2 EEC-V
FBGI0
NUMEGO Switch
Unread post by Turbo4V »
Using FBGIO_230504 definition, the ENABLE_1_NUMEGO and DISABLE_FOR_2_NUEMGO patches will not apply. "Patch Aborted. Base data does not match." That was anticipated as per the comments. I tried to just manually change all 35 of the NUMEGO switches to 1, but the patches still do not work.
Should the patches be working after manually changing all 35 of the NUMEGO switches to 1, or does the "Patch Aborted. Base data does not match" error suggest something else is wrong?
Do I even need to bother with the patches if the 35 NUMEGO switches are all 1?
Re: NUMEGO Switch
There should be 4 patches. One of which will force them all to 1.
