EEC V file conversion
Re: EEC V file conversion
Post one up.
Few I just randomly picked out of the directory. There are tons of files here that look to be pointers or data files. On of them looks to be the data for how it decodes the vin number when starting a diag session. Looks like it could be useful somehow at least. LOL
- tmlfiles.zip
- (175.49 KiB) Downloaded 428 times
Most of them seem to start with Salted__Ã or at least Salted__something. Looked that up and seems to point toward some sort of data file. A salt file or something like that. Also see http://www.liquid-technologies.com mentioned in quite a few files in this directory. Also forgot to mention the subdirectory is named XMLFILES
Salted as in salted password at a guess. Probably compressed XML, certainly file size would seem too small for an xml or even plain csv text version of a DMR.
In any case those files are for 2016 so not relevant to 806x.
Those are. There are a ton of them. Just older than about 2010 goes to just lettered files. I just need to figure out which files pertain to which strategies.
I will zip the whole directory and see how big it ends up being. Maybe I can post the zip file if it isn’t too big.
Unfortunately it ends up being too large of a file to post. 59?,??? Kb ish.
I am curious though if when you download ids install files if it would put all that on your drive even if you do not register it though. May be the easiest way for you to have all of the files on ids. There are a ton of dll files and tml and xml files in the different directories that may point to a way to read the files and get the data we need from them.
I agree install looks possible, but it appears log in is required to get calibration files.
They've gone to the trouble of salted passwords, certainly trying to keep some stuff secret.
I don't intend to spend time sifting through endless files or trying to work out the salted passwords.
I think the calibration files need to be downloaded to make any progress.
If you have something specific, I'll take a look.
I will try and figure out the naming scheme and find some files for the older EEC V vehicles that would have the older PCM in them. I did find some files listed as Barra and some that mention Ford of Australia if you are interested in those. However, upon further investigation there seems to be a ton of dll files and exe files that may uses the tml files as a library and maybe we can figure out which is which and that may tell us what we need to know to open the tml files and get the data? Not sure here, just guessing at this point. Is there a good program for finding out which exe files use which dll files and which tml files? Something that won't cost a bunch of money, LOL. Especially because I am not sure it will go anywhere. Or maybe something I can hook up between the computer and vcm to sniff out what addresses we need while hooked to the vehicle? Was just thinking if we could figure out the tml files we could also figure out how the active commands work and possibly add that stuff into tuning software for diagnosis and testing purposes?
Updated DIR and short CMT file for CRAI8. No updates to CMT file. Just what you told me to add. I think I have made good progress on this one. Still a ton to figure out though.
- CRAI8_AOL1_DIR_20240918.zip
- (216.02 KiB) Downloaded 398 times
In CRAI8, this subroutine seems to be using R26 and Rfe as RBASE value storage locations..... How do I find out what those values are exactly so I can figure out the correct function addresses for this subroutine? Seems to match up with SUB_082DA in RZASA as well, but the RBASE values aren't defined in that strategy either. You may have gone over this before, but I can't seem to remember or find the answer in previous posts. Thanks.
92197: 65,08,00,26 ad2w R26,8 TEMP1L += 8;
9219b: 3d,ad,04 jb B5,Rad,921a2 if (FLG_SFT_UP = 0) {
9219e: 65,02,00,26 ad2w R26,2 TEMP1L += 2; } } } }
921a2: 45,6e,92,26,32 ad3w R32,R26,926e TEMP7L = TEMP1L + 926e;
921a7: 46,32,fe,36 ad3w R36,Rfe,[R32] TMP2L = Rfe + [TEMP7L];
921ab: b0,30,38 ldb R38,R30 TMP3L = TEMP6L;
921ae: 91,10,a5 orb Ra5,10 SIGNDY = 1;
921b1: ef,a9,26 call 9485d SLU9485D_92C16_**YFn ();
921b4: c7,e4,2a,3c stb R3c,[Re4+2a] TV_RAMP = TMP5L;
921b8: 45,60,92,26,32 ad3w R32,R26,9260 TEMP7L = TEMP1L + 9260;
921bd: 46,32,fe,36 ad3w R36,Rfe,[R32] TMP2L = Rfe + [TEMP7L];
921c1: a3,d2,40,38 ldw R38,[Rd2+40] TMP3L = TOT;
921c5: 91,20,a5 orb Ra5,20 SIGNDSLP = 1;
921c8: ef,de,26 call 948a9 SLU948A9_92C62_**WFn ();
921cb: a0,3c,2c ldw R2c,R3c TEMP4L = TMP5L;
921ce: b0,30,39 ldb R39,R30 TMP3H = TEMP6L;
921d1: 11,38 clrb R38 TMP3L = 0;
921d3: 45,52,92,26,32 ad3w R32,R26,9252 TEMP7L = TEMP1L + 9252;
921d8: 46,32,fe,36 ad3w R36,Rfe,[R32] TMP2L = Rfe + [TEMP7L];
921dc: ef,ca,26 call 948a9 SLU948A9_92C62_**WFn ();
921df: 6c,2c,3c ml2w R3c,R2c TMP5L *= TEMP4L;
921e2: 0c,0a,3c shrdw R3c,a TMP5L >>= a;
921e5: 88,00,3e cmpw R3e,R0
921e8: df,03 je 921ed if (TMP6L != ZERO) {
921ea: bd,ff,3c ldsbw R3c,ff TMP5L = ff; }
921ed: c3,01,56,17,3c stw R3c,[R0+1756] [11756] = TMP5L;
921f2: 44,26,fc,32 ad3w R32,Rfc,R26 TEMP7L = 5d32 + TEMP1L;
921f6: 6f,33,98,10,2c ml2w R2c,[R32+1098] TEMP4L *= [TEMP7L+11098];
921fb: 0c,0a,2c shrdw R2c,a TEMP4L >>= a;
921fe: 98,00,2e cmpb R2e,R0
92201: df,03 je 92206 if (TEMP5L != ZERO) {
92203: bd,ff,2c ldsbw R2c,ff TEMP4L = ff; }
92206: c3,01,58,17,2c stw R2c,[R0+1758] [11758] = TEMP4L;
9220b: 44,26,fc,32 ad3w R32,Rfc,R26 TEMP7L = 5d32 + TEMP1L;
9220f: a3,33,84,10,3c ldw R3c,[R32+1084] TMP5L = [TEMP7L+11084];
92214: c3,e4,34,3c stw R3c,[Re4+34] [112b4] = TMP5L;
92218: b0,30,38 ldb R38,R30 TMP3L = TEMP6L;
9221b: 45,1a,92,26,32 ad3w R32,R26,921a TEMP7L = TEMP1L + 921a;
92220: 46,32,fe,36 ad3w R36,Rfe,[R32] TMP2L = Rfe + [TEMP7L];
92224: ef,36,26 call 9485d SLU9485D_92C16_**YFn ();
92227: a0,3c,34 ldw R34,R3c TMP1L = TMP5L;
9222a: b0,31,38 ldb R38,R31 TMP3L = TEMP6H;
9222d: 45,28,92,26,32 ad3w R32,R26,9228 TEMP7L = TEMP1L + 9228;
92232: 46,32,fe,36 ad3w R36,Rfe,[R32] TMP2L = Rfe + [TEMP7L];
92236: ef,24,26 call 9485d SLU9485D_92C16_**YFn ();
92239: a0,3c,36 ldw R36,R3c TMP2L = TMP5L;
9223c: ad,0a,38 ldzbw R38,a TMP3L = a;
9223f: 45,36,92,26,32 ad3w R32,R26,9236 TEMP7L = TEMP1L + 9236;
92244: 46,32,fe,3c ad3w R3c,Rfe,[R32] TMP5L = Rfe + [TEMP7L];
92248: ef,02,27 call 9494d Sxx9494D_RZA92D8E ();
9224b: c4,2c,3f stb R3f,R2c TEMP4L = TMP6H;
9224e: 11,46 clrb R46 TMP0L = 0;
92250: 45,44,92,26,32 ad3w R32,R26,9244 TEMP7L = TEMP1L + 9244;
92255: 46,32,fe,36 ad3w R36,Rfe,[R32] TMP2L = Rfe + [TEMP7L];
92259: b0,30,38 ldb R38,R30 TMP3L = TEMP6L;
9225c: 91,10,a5 orb Ra5,10 SIGNDY = 1;
9225f: ef,fb,25 call 9485d SLU9485D_92C16_**YFn ();
92262: bc,3c,3c ldsbw R3c,R3c TMP5L = TMP5L;
92265: 37,3d,04 jnb B7,R3d,9226c if (B7_TMP5H = 1) {
92268: 03,3c negw R3c TMP5L = -TMP5L;
9226a: 17,46 incb R46 TMP0L++; }
9226c: 11,3a clrb R3a TMP4L = 0;
9226e: b3,01,80,17,3b ldb R3b,[R0+1780] TMP4H = PWFC;
92273: 6c,3a,3c ml2w R3c,R3a TMP5L *= TMP4L;
92276: 30,46,02 jnb B0,R46,9227b if (B0_TMP0L = 1) {
92279: 03,3e negw R3e TMP6L = -TMP6L; }
9227b: 54,3e,2c,3c ad3b R3c,R2c,R3e TMP5L = TEMP4L + TMP6L;
9227f: 29,47 scall 923c8 Sub_923c8 ();
92281: b0,3c,47 ldb R47,R3c TMP0H = TMP5L;
92284: 08,01,26 shrw R26,1 TEMP1L >>= 1;
92287: 44,26,fc,32 ad3w R32,Rfc,R26 TEMP7L = 5d32 + TEMP1L;
9228b: b3,33,a7,10,38 ldb R38,[R32+10a7] TMP3L = [TEMP7L+110a7];
92290: c7,01,5b,17,38 stb R38,[R0+175b] [1175b] = TMP3L;
92295: b3,d2,17,c6 ldb Rc6,[Rd2+17] FLAGTEMP_BG = FLAG_EXT5;
92299: 37,c6,07 jnb B7,Rc6,922a3 if (B7_FLAGTEMP_BG = 1) {
9229c: b3,fd,7c,10,46 ldb R46,[Rfc+107c] TMP0L = S.0x16DAE;
922a1: 20,41 sjmp 922e4 goto 922e4; }
