[READ0] Strategy File
Attached brief def file I made back in 2021 with datalogging added.
If anyone wants to try it out and post back a log.
DECIPHA_240829.adx
posted 24-12-14
(491.18 KiB) Downloaded 912 times
READ0_EQE5.bin
stock bin
(256 KiB) Downloaded 1126 times
READ0_240829.xdf
(108.11 KiB) Downloaded 1110 times
Re: [READ0] Strategy File
I will see if I can get you a log this weekend. I haven't looked into the DEF file yet, are the areas defined to delete EGR, PATS, and rear Cat monitors? Those are the minimum requirements I need to make the truck run basically.
Does not poll any data at all. I can load the CRAI8 adx and it will poll data that is not correct of course, but when I load the READ0 ADX file it does not read anything at all. Just figured I would post an update. Does the file need to be named the same as it is posted to work? I renamed it with the strategy name so I can keep the adx files straight.
nah i need to add the que msg to the config
nvm, i didn't have a checksum.
Should poll data now. Give her a try. New ADX posted above. Same name as before so overwrite the old one.
PATS is there but egr and cats aren't. Aren't needed to make it run and doesn't affect anything.
When a premium member needs more I'll add more to it.
No problem. I will give it a try later today and let you kno0w. Thanks. Hopefully I may have some of it in my DIR file and can add to it. Thanks
Snake0503
Vehicle Information: 2003 ford ranger. 98' explorer 5.0 swap, 3 bar gt40 heads, trick flow stage 1 cam,1.7 crane rr, NRT1 ECU
Unread post by Snake0503 »
tired loading up the new ADX file I still could not get it to poll data
yeah something has to be configured wrong, i'll give it a look over once i get more free time to check it out fully
Snake0503
thank you
