EEC V file conversion
Re: EEC V file conversion
BOOSTEDEVERYTHING wrote: 2024 Aug 26, 08:14 Ah, Ok. Just making sure I understand why. Thanks. I went through this one like you instructed me to go through the other and kept adding the scan commands for all of the areas that were not disassembled by SAD.
Add scan commands for subroutines only. Use other commands for other binary values.
So, If I run into this again, If I find that an area that is not disassembled by SAD, ends up being one of the above, I should delete the added scan commands and just ignore the code that was not disassembled?
Yes scan commands should be removed if valid subroutines are not discovered.
Scan commands should not have been commanded in the first place for many of those I've said to delete.
If it is a subroutine it needs to be disassembled automatically or with SCA...or COD.
If it is NOT a subroutine then other commands need to be applied to correctly identify the binary values.
You can get false positives for subroutines if command are applied scatter gun style.
SCA 82005
SCA 82015
SCA 82017
SCA 82019
SCA 8201B
SCA 8201D
SCA 8201F
All fill, NOT a Sub, use FIL.
SCA 82021
SCA 82023
SCA 82025
SCA 82027
SCA 82029
SCA 8202B
SCA 8202D
SCA 8202F
SCA 82031
SCA 82033
SCA 82035
SCA 82037
SCA 82039
SCA 8203B
SCA 8203D
SCA 8203F
SCA 82041
SCA 82043
SCA 82045
SCA 82047
SCA 82049
SCA 8204B
SCA 8204D
SCA 8204F
SCA 82053
SCA 82055
SCA 82057
SCA 82059
SCA 8205B
SCA 8205D
SCA 8205F
Interrupt vector list, NOT a Sub. SAD has done it automatically.
SCA 82061
SCA 82065
SCA 82067
These addresses are operands to opcodes. Scan should start with the opcode IF needed.
Scan is not needed as SAD finds them automatically.
SCA 82069
Scan is not needed as SAD finds this automatically.
SCA 8F6FB
Fill use the fill command.
SCA 8F6FE
SCA 8F702
SCA 8F705
Part of a structure that is looped through
SAD has found the words at the start of the structure and the Sub that loops through the structure is adjacent.
As the user you need to look for f6fc being used as an address in a Sub then work out what the Sub does.
Use STR, SYM, and WOR commands to identify the binary values.
8f6fc: 82,06              word    682
8f6fe: a8,0c,2f,0f        ???
8f702: c8,16              word   16c8
8f704: 00,00,2f,0f,a8,0c,e7,97  ???
   Sub_8f70c:
8f70c: a1,40,0f,36        ldw   R36,f40          R36 = f40;
8f710: a1,fc,f6,34        ldw   R34,f6fc         R34 = f6fc;
SCA 8F775
Fill
SCA 8F778
SCA 8F77A
SCA 8F77B
Same explanation as previous structure.
8f746: a1,76,f7,36        ldw   R36,f776         R36 = f776;
SCA 9FF12
Part of the VID block, NOT a Sub.
Also, is there an easy way to determine what areas are structures and vectors? Still a bit confused by those.
Structure are blocks of binary values that may be bits, bytes, words, addresses, etc.
They are not functions, tables or subroutines.
A vector list is a type of structure containing subroutine addresses, but a VEC command is more appropriate.
A vector list is a list of subroutine addresses.
Hopefully a little clearer now. I suspect address modes might still provide some confusion for you as well, but you need to read the manuals and look at uses of each until they make sense.
BOOSTEDEVERYTHING wrote: 2024 Aug 26, 08:37 Also. I found that SAD does not like a certain area of this code so I had to keep trying subsequent lines of code for it to start a scan, Is there a reason why or is it just a bug of some kind?
SCA 855FF     # SAD V4.07.16B HAS PROBLEM WITH 855FC
You should scan from the Sub start address 855F0, though SAD comes up with this without a SCAN command for that Sub.
If you are trying to scan for a Sub from the Arg 855FC you will get interesting results.
   Sub_855f0:
855f0: f2                 pushp                  push(PSW);
855f1: 01,42              clrw  R42              R42 = 0;
855f3: 10,09              rombk 9
855f5: ef,9d,d5           call  92b95            Sub_92b95 (
855f8: 42,00                    #arg 1              42,
855fa: 6a,10                    #arg 2              106a,
855fc: ff                       #arg 3              ff,
855fd: ff                       #arg 4              ff,
855fe: 1e                       #arg 5              1e );
855ff: c3,01,d6,17,42     stw   R42,[R0+17d6]    [117d6] = R42;
85604: b0,9c,34           ldb   R34,R9c          R34 = R9c;
85607: 01,42              clrw  R42              R42 = 0;
85609: 34,98,0a           jnb   B4,R98,85616     if (B4_R98 = 1)  {
8560c: c3,01,d8,17,42     stw   R42,[R0+17d8]    [117d8] = R42;
85611: 71,f7,34           an2b  R34,f7           B3_R34 = 0;
85614: 20,e6              sjmp  856fc            goto 856fc; }
I will review the address modes section again. You are correct that they are not very clear for me yet. Odd that you are getting SAD to disassemble sections that I added SCA commands for, as I went through and only added what SAD was not disassembling automatically for me. Maybe I will go back through and comment them all out and try again.
I ran SAD against a basic DIR with your scan list less those above I said to delete. If you have missed subroutines with your DIR and excess scan commands deleted, then there is some other incorrect command in your DIR.
Delete just those above not all.
Ok, Thank you. Will do and go back through and make sure everything looks to be disassembled correctly.
Where would I get a DMR file from and What is it for or from? Is it an SCT based file or is it something that Ford uses to locate PIDS?
The ones I have come from the openeec github repository.
They are ford files, possibly from IDS or something like that.
Oh. Maybe I’ll take a look on my ids and see if I can track them down. I also have access to a couple of older ngs cards. If I can find something to hook to a computer to read them maybe there will be something on those.
Could you please post a DMR file or maybe email me one so I can see what I am looking for exactly? I can not seem to find anything on the openeec project about dmr files at all.
RZASA_DMR.zip
(55.55 KiB) Downloaded 612 times
Thanks, after looking through everything I think I found the files but am pretty sure they are encrypted or maybe just a format I do no have any idea of looking at. I am pretty sure they are stored as .TML files. I have looked around for different programs to open the files but they all come out gibberish.
