So i checked my tune and the manifold volume is set at .50 liters. Default value is 4. I can try a lower value but I am pretty sure I tried this before and it didnt help. Any other recommendations?
decipha wrote: 2021 May 01, 18:42 no i sure dont
you can go divide it in half and go from there with her
PaulC-turbo5.0
Single 67mm On3 BB turbo
tuning with Moates QH + TPRT
dleach1407 wrote: 2021 May 02, 02:39 So i checked my tune and the manifold volume is set at .50 liters. Default value is 4. I can try a lower value but I am pretty sure I tried this before and it didnt help. Any other recommendations?
do you have the transient fuel multipliers I mentioned? I know how frustrating an issue like this is, you think you got the car dialed in nicely but every time you get going you have to get through this crap first. Thankfully mine is much better now but still isnt perfect and that bugs me.
Decipha if you were remote tuning this for him what would you be trying to adjust to remedy this?
I dont think it would be something mechanical, do you agree with that?
When remote tuning for people do you ever run into odd issues like these that you cant solve and essentially you and the owner have to call it good enough?
I would keep cutting manifold volume til the problem is solved.
No I've never had an issue I couldn't fix.
The weather has been shit the last few days and I've been working on my truck when i can. I haven't messed with the tune since Friday night. What is the lowest number i can use in that field? Can i use negative numbers? I would assume 0 is the lowest number supported in that field.
PaulC-turbo5.0 wrote: 2021 May 04, 12:25
The only other transient fuel table i can find is fn312qd which is tip in transient fuel based on ECT. This also seems like it could be something I could adjust to help. The issue is much worse when cold so I feel i could maybe adjust that. I dont see anything called AEM in my tune so maybe it is called something different
aem was replaced by manifold volume
decipha wrote: 2021 May 04, 23:29 aem was replaced by manifold volume
Would Tip in transient fuel be another place to look if manifold volume doesnt help? I am pretty sure I set it to 0 once before and it still didnt fix the issue.
manifold volume of 0 would be a problem
PaulC-turbo5.0
Decipha is this any sort of a common issue you have ran into before? Seems odd that both of us have been dealing with it and not much luck over a pretty long time trying to remedy it?
OP post a log of this happening whenever you can and I'll do the same. I am now logging my WB so it will show better then in the past. Maybe at that point we can put some coin together and pay Decipha to help us fix it lol.
