What would be normal to see for trans temp.
Im running a 3000 stall Edge Converter, trans go shift kit, 4r70w pan, and a tru-cool 24,000 gvw 8x11 cooler.
Autometer temp gauge is in the test port.
I went for a 1 hour city cruize which is longer then a normal drive for me and temps got as high as 210. I used to see 180 on shorter drives.
Radiator heat soak? Still using the stock fan temps and i only changed transmission settings for 3.27 to 3.73 gears.
AODE trans temps
Danno5.0
- Vehicle Information: 1995 Ford Mustang GT
W4HO
Crane 2031 cam
Ported E7 heads
Mac shorties, xpipe, mufflers
3000 stall, Transgo, 3.73
Tweecer R/T, LC1 wb
Re: AODE trans temps
yeah definitely, need to bypass the radiator.
180 is ideal, every 10 degrees over that gives you a good bit more wear.
