1DGA disassembly
Re: 1DGA disassembly
Was the consolidated DIR of no value to you?
Jamie from oz
- Vehicle Information: 1995 ford falcon ute 5.0 windsor efi
I have been doing both and yes it has helped heaps.
just wanted to post the one that Dimitrios can also use for now
Why is he unable to use the consolidated one?
Jamie from oz
I am not sure if he has yet.
Jamie from oz
Almost finished the functions in the consolidated dir.
Should get that part finished tomorrow.
Jamie from oz
Have named the tables and functions also aligned the A9L ones if you want to check my progress.
will start on the scalers next.
The cross matches I've looked at look good.
At some point the DIR commands will need to be put into a definition of one flavour or another. Retyping all that info is undesirable. I see you have taken the names from A9L DIR unchanged, which is perfectly ok, however the layout of the resulting DIR does not lend itself to conversion. The A9L dir was done long before the idea of automating some info transfer.
You may have noted that the consolidated DIR I generated has a consistent layout. Also have a look at the more complete RZASA I've posted in another thread. They were generated by getting data and processing it consistently. Ideally reversing that process can save a lot of manual retyping to build a definition. In the 1DGA DIR some Fn names are at the beginning, some at the end and some not at all. The beginning suits conversion because it starts at a set number of characters. Yes. some names maybe unknown so Fnx8A12 is better than nothing.
Copy the function and associated sym's to an excel worksheet, likewise tables to another, now try using text to columns to break out the address, FN name, sign and size from the commands. Could consistent layout make that easier?
Looking at Sub_49DD is 1DGA which matches Sub17 in TVRfans A9L.
I'd be inclined to name the Sub, something like;
If I could find an exact subroutine match in the strategy docs, I'd name it after that.
This could be cleaned up by combining the correct info and eliminating the repeats.
Likewise for others as you progress.
I've looked in the GUFB strategy to confirm an appropriate function name.
Becomes something like;
List looks like;
The first line is a comment from a CMT file entry.
With a view to generating a definition the commands would be broken up in a spreadsheet, something like;
Name;
Short description;
Sign;
Size;
X Equation;
Y Equation;
Address;
At some future point a database of Function names may be used to build detailed descriptions and other info into definition conversion, but that's not soon.
SCA and STR commands need to be added to tidy up the disassembly.
Have a look at the table at 0x8EFD in the DIR, drop the bank off of the end address. Yes the consolidated DIR should not have it to start with, my conversion mistake.
SUB 49DD "Sub49DD_Adptv"
sym 8a1e "Spk_Injector_timing_Maf_Backflow_Sclr~RPM(Rpmscale)" #{4}
fun 8a1e 8a39: UW X 10 : UW X 10 V 256 #{4}
#SYM8A1E "uuwFn070" #Spark, Injector Timing, MAF Backflow Scaler for RPM {2}
#FUN8A1E 8A39 :UW :UW #[UW=flo(X/4)] [UW=flo(X/256)] #rpm>column {2}
#SYM8A1E "uuwFn.0x8a1e" # {3}
#FUN8A1E 8A39 :UW :UW #[UW=flo(x*1)] [UW=flo(X/256)] #>SC {3}
SYM 8A1E "uuwFn070_Adp_MAF-Bf_Inj_Spk~RPM" #RPM Normalizing function for Spark, Injector Timing, MAF Backflow. GUFB 6-38 {0}
FUN 8A1E 8A39 :UW V 4 :UW V 256 #[UW=flo(X/4)] [UW=flo(X/256)] #rpm>column {0}The first line is a comment from a CMT file entry.
# rpm > column
uuwFn070_Adp_MAF-Bf_Inj_Spk~RPM:
8a1e: ff,ff,00,09 func 16383.75 , 9
8a22: 80,3e,00,09 func 4000 , 9
8a26: e0,2e,00,08 func 3000 , 8
8a2a: 70,17,00,05 func 1500 , 5
8a2e: f0,0a,00,01 func 700 , 1
8a32: c4,09,00,00 func 625 , 0
8a36: 00,00,00,00 func 0 , 0
Name;
Fn070
or
U
W
X/4
X/256
8A1E
Jamie from oz
Yes it's coming along slowly.
When I have them all in the dir I was going to add the short names (eg FN070 )
I didn't remove any extra lines that have the reference of origin as its been a good cross-reference.
Will look at that table and there was also a couple functions that had table naming in the A9L dir/cmt .
The 1dga xdf has most of the scalers functions and tables ### commented out and I will correct them for now and see if you can help me make a BE file and QH payload at some point.
Sounds good.
I'll suss out the payload in the mean time.
Chuck these in the DIR
Sub 2032 "Sub2032_InitAll_Rst" # {0}
Sub 2151 "Sbg2151_BG_Looper" # {0}
SUB 2172 "Sbg2172_BG_LoopOfDeath" # {0}
Sub 860B "Sbg860B_Cal_Console" # {0}
Sub 860C "Sbg860C_CC/Patch" # Call Calibration Console or Patchcode {0}
