1DGA disassembly
Jamie from oz
- Vehicle Information: 1995 ford falcon ute 5.0 windsor efi
Re: 1DGA disassembly
Yes they have used a template and just ### out all the things they haven't found .
Won't be too hard to find most of the main things.
No, it's more than that.
Yeah, stand back, I'll wave the wand.
Jamie from oz
Dimitrios now you have sad working and a 1dga_256k_dir we can try to find things .
you had looked in the A9L _lst and seen the code / calibration below
so the same looking code / calibration from 1DGA that you pointed out can be followed to see if its what you think.
A9L
1DGA
so we could assume this is same .
1gda dir entry
the # DT # is that you found that for later reference .
9ada: 0a byte a DFSVS # Fuel Shut Off Deceleration Min MPH - DFSVS
9adb: 04 byte 4 DFSVSH # Fuel Shut Off Deceleration Min MPH Hysterysis - DFSVSH
9adc: 00,00 word 0
9ade: 00,00 word 0
9ae0: 00 byte 0
9ae1: 00 byte 0 # Fuel Shut Off PT Enable - 1 = PT decel fuel shut off, 0 = CT decel fuel shut off.
9ae2: 55 byte 55 MinECT_adp # Adaptive ECT Min - AFECT1
9ae3: 71 byte 71 MaxECT_adp
9ae4: 32 byte 32 Minact_adp # Min ACT for Adaptive Control - AFACT1
9ae5: 64 byte 64 Maxact_adp # Max ACT for Adaptive Control - AFACT2
9ae6: 3c,00 word 3c ADAPTIM # Adaptive Delay Time - ADAPTM
9ae8: 7b,04 word 47bso the same looking code / calibration from 1DGA that you pointed out can be followed to see if its what you think.
9822: 0a byte a
9823: 04 byte 4
9824: 00,00 word 0
9826: 00,00 word 0
9828: 00 byte 0
9829: 00 byte 0
982a: 55 byte 55
982b: 71 byte 71
982c: 32 byte 32
982d: 64 byte 64
982e: 3c,00 word 3c
9830: 7b,04 word 47bCode: Select all
4e20: b3,fc,5c,1a ldb R1a,[Rfc+5c] R1a = DFSVS;
4e24: 9b,74,3f,1a cmpb R1a,[R74+3f]
4e28: d9,05 jgtu 4e2f if (R1a <= Mph_FiltH) {
4e2a: 91,08,ca orb Rca,8 Dfsvs_hys_flag = 1;
4e2d: 20,0f sjmp 4e3e goto 4e3e; }
4e2f: 7b,fc,5d,1a sb2b R1a,[Rfc+5d] R1a -= DFSVSH;
4e33: d3,09 jnc 4e3e if (R1a >= 0) {
4e35: 9b,74,3f,1a cmpb R1a,[R74+3f]
4e39: d1,03 jleu 4e3e if (R1a > Mph_FiltH) {
4e3b: 71,f7,ca an2b Rca,f7 Dfsvs_hys_flag = 0; } }
4e3e: a3,74,de,34 ldw R34,[R74+de] R34 = Load; # engine load (VE? )
4e42: 8b,fc,5e,34 cmpw R34,[Rfc+5e]
4e46: db,05 jc 4e4d if (R34 < [9adc]) {Code: Select all
4ed8: b3,fc,60,1a ldb R1a,[Rfc+60] R1a = [9822];
4edc: 9b,74,3b,1a cmpb R1a,[R74+3b]
4ee0: d9,05 jgtu 4ee7 if (R1a <= 2bb_MPH_FiltH) {
4ee2: 91,08,ca orb Rca,8 B3_Rca = 1;
4ee5: 20,0f sjmp 4ef6 goto 4ef6; }
4ee7: 7b,fc,61,1a sb2b R1a,[Rfc+61] R1a -= [9823];
4eeb: d3,09 jnc 4ef6 if (R1a >= 0) {
4eed: 9b,74,3b,1a cmpb R1a,[R74+3b]
4ef1: d1,03 jleu 4ef6 if (R1a > 2bb_MPH_FiltH) {
4ef3: 71,f7,ca an2b Rca,f7 B3_Rca = 0; } }
4ef6: a3,74,da,34 ldw R34,[R74+da] R34 = 25a_load;
4efa: 8b,fc,62,34 cmpw R34,[Rfc+62]
4efe: db,05 jc 4f05 if (R34 < [9824]) {so we could assume this is same .
1gda dir entry
sym 9822 9822 "9822_DFSVS" # DT # (9ada in a9l)
sym 982a 982a "982a_minect_adp" # (9ae2 in a9l)-
Dimitrios
- Vehicle Information: 1992 Ford EB Falcon XR8, EEC IV, custom cam ported and shaved e7, explorer manifold, j3 chip.
Thanks Mate i’ll check it all out shortly on laptop
Jamie from oz
Consolidated DIR with commands from the quoted post.Jamie from oz wrote: ↑2024 Jul 29, 18:23 to be put into a text file 1DGA_256k_dir
was using sad v4.12a
jamie.
I've not added info from your more recent posts.
Jamie from oz
Will check it outjsa wrote: ↑2024 Aug 04, 05:07Consolidated DIR with commands from the quoted post.Jamie from oz wrote: ↑2024 Jul 29, 18:23 to be put into a text file 1DGA_256k_dir
jamie.
1DGA_256k_DIR.zip
Thanks John
Jamie from oz
I am adding tables to the consolidated dir
Will keep you updated on progress.
Cool
Jamie from oz
have done some of the Dir tables and functions .
and slowly adding scalers and payloads.
just for reference i have posted the dir.zip
