05' Slot MAF IAT transfer
Neald
Vehicle Information: 1989 Ford Bronco II
Stock 2.9 V6, A4ld trans.
CBAZA(6CYL Config)
Moates quarterhorse
Unread post by Neald »
Hello everybody. Im looking to see if anyone has the IAT transfer function for the 05 Mustang Slot MAF. I cannot find it in any search. Also tried looking for an 05 GT xdf to grab it from in tunerpro, but cannot find it either im guessing because its 05+. Thanks and have a great day
Re: 05' Slot MAF IAT transfer
I've never checked the iat transfer, AFAIK its close enough (maybe the same) to the older thermisters to never have had to at least I've never done it or questioned it.
There is no 05 xdf, thats premium member stuff and you need a mongoose and pcmflash to read and write 2005-2020 ecu's for tunerpro.
Here is from the 2005 PCED for a 2005 Mustang GT
  TEMPERATURE SENSOR VOLTAGE AND RESISTANCE SPECIFICATIONS
Temperature	Temperature Sensor Values
°C	°F	Voltage	Resistance (K ohms)
120	248	0.28	1.18
110	230	0.36	1.55
100	212	0.47	2.07
90	194	0.61	2.80
80	176	0.80	3.84
70	158	1.05	5.37
60	140	1.37	7.70
50	122	1.77	10.97
40	104	2.23	16.15
30	86	2.74	24.27
20	68	3.26	37.30
10	50	3.73	58.75
0	32	4.14	95.85
-10	14	4.45	160.31
Neald
CBAZA(6CYL Config)
Moates quarterhorse
Im currently using my original sensor in the intake manifold. And thought years ago to convert to the slot MAF iat since it's installed anyway . I recently solidified that idea when I read that in the pre tune portion of the website. I appreciate the help and responses. Maybe as an idea, post this iat transfer in the pre tune or MAF transfer page. Have a great day !!
