EEC V file conversion
Re: EEC V file conversion
Yes L09777 sets the column quantity.
Yes two functions to get row and column, then do the table lookup.
You could add the function subs to your code sequence.
Sure, post up your analysis.
Have you spotted any code for the row count?
No I have not, but I would assume by the functions it calls it would be 8, but It is 16, So I am very confused about how it all works exactly. Looks like it Checks the table 3 times before outputting a value. But I am lost after adding all of the extra code it takes to actually perform a table lookup. Seems very overcomplicated but I am sure I am making it that way in my head..Have you spotted any code for the row count?
Here is the complete Table lookup....I think?
ROUTINE FOR swTb34EPPH
09756: a1,1c,5d,36 ldw R36,5d1c TMP2L = uuyFn.0x15d1c;
uuyFn.0x15d1c:
15d1c: ff,70 func 255, 112
15d1e: 50,60 func 80, 96
15d20: 28,40 func 40, 64
15d22: 00,00 func 0, 0
15d24: 00,10 func 0, 16
15d26: 00,10 func 0, 16
15d28: 00,10 func 0, 16
15d2a: 00,10 func 0, 16
0975a: b3,01,93,f3,38 ldb R38,[R0+f393] TMP3L = VS_U4_DELTA;
0975f: 10,09 rombk 9
09761: ef,84,93 call 92ae8 SLU92AE8_UUYFn ();
SLU92AE8_UUYFn:
92ae8: f2 pushp push(PSW);
# SJump Loop from L92AF3 until Process Value >= value @ Fn_Addr+2 SLU92AE8_UUYFn
92ae9: 9b,36,02,38 cmpb R38,[R36+2]
92aed: db,06 jc 92af5 if (TMP3L < [Fn_Addr+2]) { # Unsigned Operation
92aef: 65,02,00,36 ad2w R36,2 Fn_Addr += 2; # Increment to Next Row
92af3: 27,f4 sjmp 92ae9 goto 92ae9; }
# JC from L92AED Process Value >= value @ Fn_Addr+2 and PV is Unsigned SLU92AE8_UUYFn
92af5: 71,df,a2 an2b Ra2,df SIGNDSLP = 0; # SIGNDSLP Clear 0
92af8: b2,37,3a ldb R3a,[R36++] TMP4L = [Fn_Addr]; # R3A = X>PV
92afb: b2,37,3c ldb R3c,[R36++] TMP5L = [Fn_Addr]; # R3C = Yx>pv
92afe: 7a,36,3a sb2b R3a,[R36] TMP4L -= [Fn_Addr]; # R3A Xd = X>PV - X<PV
92b01: 7a,37,38 sb2b R38,[R36++] TMP3L -= [Fn_Addr]; # R38 PVd = PV - X<PV
92b04: 7a,36,3c sb2b R3c,[R36] TMP5L -= [Fn_Addr]; # R3C Yxd = Yx>pv - Yx<pv
92b07: db,05 jc 92b0e if (TMP5L < 0) { # Unsigned Operation
# Unsigned CV Increases by Row
92b09: 91,20,a2 orb Ra2,20 SIGNDSLP = 1; # Yxd Negative
92b0c: 13,3c negb R3c TMP5L = -TMP5L; } # Invert Yxd Positive
# Cont from L92B0C CV Increased by Row, Negative Yxd Inverted Positive SLU92AE8_UUYFn
# JC from L92B07 Unsigned Control Value Decreases by Row, Yxd Positive SLU92AE8_UUYFn
92b0e: 7c,38,3c ml2b R3c,R38 TMP5L *= TMP3L; # R3C = Yxd * PVd
92b11: 9c,3a,3c divb R3c,R3a TMP5L /= TMP4L; # R3C CVd = Yxd * PVd / Xd
92b14: 35,a2,02 jnb B5,Ra2,92b19 if (SIGNDSLP = 1) {
92b17: 13,3c negb R3c TMP5L = -TMP5L; } # Revert Negative
# Cont from L92B17 CVd Control Value Delta Reverted to Negative SLU92AE8_UUYFn
# JNB from L92B14 CVd Control Value Delta Positive SIGNDSLP = 0 SLU92AE8_UUYFn
92b19: 76,36,3c ad2b R3c,[R36] TMP5L += [Fn_Addr]; # R3C CV = CVd + Yx<pv
92b1c: 11,3d clrb R3d TMP5H = 0; # CV High Byte Clear 0
92b1e: 71,df,a2 an2b Ra2,df SIGNDSLP = 0; # Clear 0 SIGNDSLP
92b21: 71,ef,a2 an2b Ra2,ef SIGNDY = 0; # Clear 0 SIGNDY
92b24: f3 popp PSW = pop();
92b25: f0 ret return;
09764: ac,3c,34 ldzbw R34,R3c TMP1L = TMP5L;
09767: a1,2c,5d,36 ldw R36,5d2c TMP2L = uuyFn.0x15d2c;
uuyFn.0x15d2c:
15d2c: ff,70 func 255, 112
15d2e: c8,70 func 200, 112
15d30: ac,60 func 172, 96
15d32: 64,00 func 100, 0
15d34: 00,10 func 0, 16
15d36: 00,10 func 0, 16
15d38: 00,10 func 0, 16
15d3a: 00,10 func 0, 16
0976b: b3,e4,fd,38 ldb R38,[Re4+fd] TMP3L = VSBART_RT;
0976f: 10,09 rombk 9
09771: ef,74,93 call 92ae8 SLU92AE8_UUYFn ();
SLU92AE8_UUYFn:
09774: ac,3c,36 ldzbw R36,R3c TMP2L = TMP5L;
09777: ad,08,38 ldzbw R38,8 TMP3L = 8; = (Table Width) 8 COLUMNS
0977a: a1,3c,5d,3c ldw R3c,5d3c TMP5L = swTb34EPPH;
swTb34EPPH:
15d3c: 00,fc,00,02,cd,00,9a,00 table 0, 252, 0, 2, 205, 0, 154, 0
15d44: 00,00,00,00,33,00,00,f6 table 0, 0, 0, 0, 51, 0, 0, 246
15d4c: 00,fc,00,00,00,00,00,00 table 0, 252, 0, 0, 0, 0, 0, 0
15d54: 00,00,00,00,33,00,00,f6 table 0, 0, 0, 0, 51, 0, 0, 246
15d5c: 00,fc,00,00,00,00,00,00 table 0, 252, 0, 0, 0, 0, 0, 0
15d64: 00,00,00,00,00,00,00,f6 table 0, 0, 0, 0, 0, 0, 0, 246
15d6c: 00,fc,00,00,00,00,00,00 table 0, 252, 0, 0, 0, 0, 0, 0
15d74: 00,00,00,00,00,fe,00,f6 table 0, 0, 0, 0, 0, 254, 0, 246
15d7c: 00,fc,00,00,00,00,00,00 table 0, 252, 0, 0, 0, 0, 0, 0
15d84: 00,00,00,00,00,fe,00,f6 table 0, 0, 0, 0, 0, 254, 0, 246
15d8c: 00,fc,00,00,00,00,00,00 table 0, 252, 0, 0, 0, 0, 0, 0
15d94: 00,00,00,00,00,f6,00,f6 table 0, 0, 0, 0, 0, 246, 0, 246
15d9c: 00,fc,00,00,00,00,00,00 table 0, 252, 0, 0, 0, 0, 0, 0
15da4: 00,00,00,00,00,f6,00,f6 table 0, 0, 0, 0, 0, 246, 0, 246
15dac: 00,fc,00,00,00,fe,00,f6 table 0, 252, 0, 0, 0, 254, 0, 246
15db4: 00,f6,00,f6,00,f6,00,f6 table 0, 246, 0, 246, 0, 246, 0, 246
0977e: 10,09 rombk 9
09780: ef,b0,96 call 92e33 SLU92E33_Y16SWTb ();
CONTINUED BELOW
# Word Table Lookup with 4 Cell Interpolate. Signed and Unsigned Word Output.
# Byte size PVC column and PVR row values are multiplied by 16 on entry.
# PVC Process Value Column is Unsigned Byte or Word.
# PVR Process Value Row is Unsigned Byte or Word.
# Tb.CV Control Value is Signed when TblSflg is Set 1
# Input: R34 PVC Column to look up. = TMP1L (VS_U4_DELTA)
# Input: R36 PVR Row to look up. = TMP5L (VSBART_RT)
# Input: R38 Cq Quantity of Columns in Table (Table Width) = 8 AS PER LINE 09777 ABOVE
# Input: R3C Tb_Addr Table Address = swTb34EPPH (0x15d3c)
# Output: R3E Tb.CV Control Value (Lookup result Output Value) = TMP6L
###### Entry Point for PVC & PVR Byte Input / Tb.CV Signed Word Output
# Call from L09780 Sub_0954e
SLU92E33_Y16SWTb:
92e33: f2 pushp push(PSW);
92e34: 91,80,96 orb R96,80 TblSflg = 1; # Signed Table B7 Set 1
92e37: 00 skip goto 92e39;
92e39: 11,35 clrb R35 TMP1H = 0; # yPVC^
92e3b: 09,04,34 shlw R34,4 TMP1L <<= 4; # wPVC * 16
92e3e: 11,37 clrb R37 TMP2H = 0; # yPVR^
92e40: 09,04,36 shlw R36,4 TMP2L <<= 4; # wPVR * 16
92e43: 20,06 sjmp 92e4b goto 92e4b;
92e4b: 5c,37,38,3e ml3b R3e,R38,R37 TMP6L = TMP3L * TMP2H; # wR3E = Cq * PVR^
92e4f: b0,34,3a ldb R3a,R34 TMP4L = TMP1L; # yR3A = yPVC
92e52: b0,36,3b ldb R3b,R36 TMP4H = TMP2L; # yR3B = yPVR
92e55: ac,35,34 ldzbw R34,R35 TMP1L = TMP1H; # wR34 = yPVC^
92e58: 64,34,3e ad2w R3e,R34 TMP6L += TMP1L; # wR3E = (Cq * PVR^) + PVC^
92e5b: 09,01,3e shlw R3e,1 TMP6L <<= 1; # wR3E = ((Cq * PVR^) + PVC^) * 2
92e5e: 64,3e,3c ad2w R3c,R3e Tb_Addr += TMP6L; # Tb_Addr = Tb_Addr + ((Cq * PVR^) + PVC^) * 2
92e61: a2,3d,34 ldw R34,[R3c++] TMP1L = [Tb_Addr]; # CV1 (Word Size)
92e64: a2,3c,36 ldw R36,[R3c] TMP2L = [Tb_Addr]; # CV2 (Word Size)
92e67: 28,25 scall 92e8e SLU92E8E_wTb.Interpolate (); # Pass 1
# Word Table 4 Cell Interpolate. Signed and Unsigned Word Output.
# SCall from L92E67 Pass 1; Lo Row, Lo & Hi Column values SLU92E4A_WUWTb SLU92E8E_wTb.Interpolate:
92e8e: ac,3a,3e ldzbw R3e,R3a TMP6L = TMP4L; # wR3E = yPVC Pass 1
92e91: 37,96,01 jnb B7,R96,92e95 if (TblSflg = 1) { # Jump FE if Interpolate Unsigned
92e94: fe,4c,36,3e,44 sml3w R44,R3e,R36 TMP9L = TMP6L * TMP2L; # lR44 = wPVC * wCV2 Pass 1
92e99: 37,96,01 jnb B7,R96,92e9d if (TblSflg = 1) { # Jump FE if Interpolate Unsigned
92e9c: fe,4c,34,3e,40 sml3w R40,R3e,R34 TMP7L = TMP6L * TMP1L; # lR40 = wPVC * wCV1 Pass 1
# JNB from L92E99 TblSflg = 0 SLU92E8E_wTb.Interpolate
92ea1: 68,40,44 sb2w R44,R40 TMP9L -= TMP7L; # wR44 = wR44 - wR40
92ea4: a8,42,46 sbbw R46,R42 TMP0L -= TMP8L - CY; # wR44^^ = wR44^^ - wR40^^ - cy
92ea7: c4,36,44 stb R44,R36 TMP2L = TMP9L; # yR36 = y(wR44 - wR40)
92eaa: 0c,08,44 shrdw R44,8 TMP9L >>= 8; # lR44 = (lR44 - lR40) / 256
92ead: 44,34,44,3e ad3w R3e,R44,R34 Tb.CV = TMP9L + TMP1L; # Tb.CV = w(l)R44 - CV1 Pass 1
92eb1: 37,96,03 jnb B7,R96,92eb7 if (TblSflg = 1) { # Is Interpolate Signed
92eb4: 3f,3f,05 jb B7,R3f,92ebc if (B7_TMP6H = 1) return; } # Is Tb.CV Negative
# Cont from L92EB4 Tb.CV Signed value positive SLU92E8E_wTb.Interpolate
# JNB from L92EB1 Tb.CV Unsigned value TblSflg = 0 SLU92E8E_wTb.Interpolate
92eb7: 37,36,02 jnb B7,R36,92ebc if (B7_TMP2L = 1) { # Is y(wR44 - wR40) < x80
92eba: 07,3e incw R3e Tb.CV++; } }
# JB from L92EB4 Tb.CV Signed value negativeB7_TMP6H = 1 SLU92E8E_wTb.Interpolate
# JNB from L92EB7 y(wR44 - wR40) < x80 B7_TMP2L = 0 SLU92E8E_wTb.Interpolate
92ebc: f0 ret return;
92e69: 09,01,38 shlw R38,1 TMP3L <<= 1; # Cq = Cq * 2 (Word Width)
92e6c: 64,38,3c ad2w R3c,R38 Tb_Addr += TMP3L; # Tb_Addr = Tb_Addr + Cq
92e6f: a2,3c,36 ldw R36,[R3c] TMP2L = [Tb_Addr]; # CV4 (Word Size)
92e72: 05,3c decw R3c Tb_Addr--; # Tb_Addr = Tb_Addr - 1
92e74: 05,3c decw R3c Tb_Addr--; # Tb_Addr = Tb_Addr - 1
92e76: a2,3c,34 ldw R34,[R3c] TMP1L = [Tb_Addr]; # CV3 (Word Size)
92e79: a0,3e,38 ldw R38,R3e TMP3L = TMP6L; # R38 = wCV1|2
92e7c: 28,10 scall 92e8e SLU92E8E_wTb.Interpolate (); # Pass 2
# SCall from L92E7C Pass 2; Hi Row, Lo & Hi Column values SLU92E4A_WUWTb
# wR3E = yPVC Pass 2
# lR44 = wPVC * wCV4 Pass 2
# JNB from L92E91 TblSflg = 0 SLU92E8E_wTb.Interpolate
# lR40 = wPVC * wCV3 Pass 2
# Tb.CV = w(l)R44 - CV3 Pass 2
92e7e: a0,3e,36 ldw R36,R3e TMP2L = TMP6L; # R36 = wCV3|4
92e81: a0,38,34 ldw R34,R38 TMP1L = TMP3L; # R34 = wCV1|2
92e84: b0,3b,3a ldb R3a,R3b TMP4L = TMP4H; # R3A = yPVR
92e87: 28,05 scall 92e8e SLU92E8E_wTb.Interpolate (); # Pass 3
# SCall from L92E87 Pass 3; Interpolated Lo Row & Hi Row values SLU92E4A_WUWTb
# wR3E = yPVR Pass 3
# lR44 = wPVR * wCV3|4 Pass 3
# lR40 = wPVR * wCV1|2 Pass 3
# Tb.CV = w(l)R44 - CV1|2 Pass 3
92e89: 71,7f,96 an2b R96,7f TblSflg = 0; # Reset B7 Clear 0
92e8c: f3 popp PSW = pop();
92e8d: f0 ret return;
CONTINUED FROM ABOVE
09783: a0,3e,3c ldw R3c,R3e TMP5L = TMP6L; = (Lookup result Output Value) -
The two functions scale inputs to table dimensions as outputs. So an 8x8 table is a fair call.BOOSTEDEVERYTHING wrote: ↑2024 May 31, 10:20 No I have not, but I would assume by the functions it calls it would be 8, but It is 16, So I am very confused about how it all works exactly.
Search for 15CDC does not find any hits in the code.
I've seen tables where two different subroutines access the same table but use different row counts, though that is not evident in this case.
Note swTb23EPPH @ 15c9c is similar.
The column scaler is unusual in that output increases above 0 for the last four rows after the input drops to 0.
The function lookup won't look in those lower 4 function rows as the input has hit the minimum input in the row above.
uuyFn.0x15d1c:
15d2a: 00,10 func 0, 16Code: Select all
uuyFn.0x15d2c:
Interpolation. Rather than take the value at the intersection of the row and column, the four nearest cells are interpolated.Looks like it Checks the table 3 times before outputting a value.
Looks ok.Here is the complete Table lookup....I think?
EDIT: See bug details in post below.
Should have dawned on me earlier. You have found a bug.BOOSTEDEVERYTHING wrote: ↑2024 May 31, 10:20Code: Select all
09777: ad,08,38 ldzbw R38,8 TMP3L = 8; = (Table Width) 8 COLUMNS 0977a: a1,3c,5d,3c ldw R3c,5d3c TMP5L = swTb34EPPH; 09780: ef,b0,96 call 92e33 SLU92E33_Y16SWTb ();
The table name starts with sw, that is signed word.
The lookup sub Y16SW, that is byte input multiplied by 16, signed word output.
You see the problem...
The table is being treated as bytes.
It should be 2 bytes per word.
8 columns requires 16 bytes per row.
So 8 words per row (16bytes) x 8 rows, problem solved.
@TVRfan
V5.08 has this bug also.
So would there be a way for me to correct how it is being treated? Or would that have to be fixed in the actual SAD programming?You see the problem...
Not sure I understand this.The row scaler is even more unusual in that an input between 100 and 0 increases the column from 0 to 1.
Really needs a programming fix on SAD.
You could bodge it with a structure command.
A value above 100 and a value below 100 lookup the same column location.
A/C << Error - Invalid Command
unded << Error - Invalid Command
icator << Error - Invalid Command
vehicles << Error - Invalid Command
e << Error - Invalid Command
ons << Error - Invalid Command
ing << Error - Invalid Command
l << Error - Invalid Command
exceed << Error - Invalid Command
to << Error - Invalid Command
dition << Error - Invalid Command
ssion) << Error - Invalid Command
signal << Error - Invalid Command
commanded << Error - Invalid Command
l << Error - Invalid CommandI got the above when I added some descriptions to some trouble codes in my DIR file. Was thinking maybe some are too long? They are on the same line as the #.
Are those character 256 or 257?
Sorry, I don’t understand your question.
