best new laptop for $500
I need a new laptop, whats the best bang for the buck I can get for $500
Re: best new laptop for $500
Assuming you don't care about a touchscreen or 2in1 convertable.
https://www.walmart.com/ip/Lenovo-Ideap ... 82SG00BLUS
If you can spring an extra 100 bucks:
https://www.lenovo.com/us/en/p/laptops/ ... ZUQAvD_BwE
- Vehicle Information: 1993 Ford Thunderbird SC
3.8L V6
8.8:1 compression
polished SC crank
Ross custom pistons
Eagle rods
dual valve springs
Precision 46mm waste gate
3" exhaust w/ cutout
FMIC
SCT BA5000 MAF
Tial Q 50mm BOV
80lb Siemens Deka injectors
modified F-150 4.2 fuel rail
Walbro 450 HP pump
8AN feed, 6AN return
wbo2_lc1mtxl
i second efloth's lenovo recommendation. imo they're the best no-frills, simple, cheap, functional laptops. one thing i like about most of their models too is that the ac adapter connector is usually a rectangular port - the cheap barrel type connectors are basically guaranteed to fail at some point if you're always plugging it in/unplugging it and they're likely going to break off the board if you accidentally yank it.
- Vehicle Information: 1995 Ford F150 XLT 4x4 5L manual M5OD-R2 (might upgrade to ZF5 later), 3.55 diffs, 30" tires (31.7" planned), e-fan (separate temp sensor, Flexalite 295)
EFI-SD42F / JOY0
Tuning a 347 w/ RV cam, 1.7 rollers, 60lb deka injectors, but otherwise stock (in particular the stock 30-45lb FPR). Emissions vehicle.
WB_AEM-X
If you want something less throwaway, Framework has cheap b-stock of their first gen laptops. Fantastic build quality, and you can upgrade everything on them as time goes on. Battery life sucked on the 1st and 2nd gens, though, and the $500 doesn't include memory, WiFi, storage, or expansion cards, so it doesn't quite fit your budget unless you can pull that stuff off of another laptop (expansion cards are $10~$20)
any recommendations for a smaller screen?
the smaller the better. I used to have a 7" back in the day that was perfect
i do a lot of traveling so being able to set it on the tray trable on an airplane is extremely beneficial.
EFI-SD42F / JOY0
WB_AEM-X
That size category has been taken over by tablets, unfortunately. Assuming you're looking for a Windows machine?
yeah
the issue i have with lenovo is its no so easy to swap batteries
my last lenovo blew out the video card cuz the battery isnt removable during a screen replacement
would rather not have to assemble and install windows etc..
I’ve always had dells, my 13” dell xps is perfect, cost around 1200, going on 7 years, has windows 11, just upgraded to 2TB hard drive
this is in the lead right now, few more bucks $800
https://www.amazon.com/Lenovo-IdeaPad-2 ... psc=1&th=1
EFI-SD42F / JOY0
WB_AEM-X
15" definitely won't be usable on a plane, though...
