TunerPro RT Update 5.00.9995
The current update has been out since Decemember and has been working perfectly. Posting this here in case anyone is still using an outdated version from that little datalogging error we had last year.
http://www.tunerpro.net/downloadApp.htm
Re: TunerPro RT Update 5.00.9995
Will downloading the update write over what I downloaded in October 2023 or do I need to go to add/remove programs and remove my old copy of TunerPro RT first before downloading TP RT 5.00.9995 ?
Turbo Tbird
Vehicle Information: 1993 Ford Thunderbird SC
3.8L V6
8.8:1 compression
polished SC crank
Ross custom pistons
Eagle rods
dual valve springs
Precision 46mm waste gate
3" exhaust w/ cutout
FMIC
SCT BA5000 MAF
Tial Q 50mm BOV
80lb Siemens Deka injectors
modified F-150 4.2 fuel rail
Walbro 450 HP pump
8AN feed, 6AN return
wbo2_lc1mtxl
Unread post by Turbo Tbird »
ATPCR wrote: 2024 Jun 15, 15:26 Will downloading the update write over what I downloaded in October 2023 or do I need to go to add/remove programs and remove my old copy of TunerPro RT first before downloading TP RT 5.00.9995 ?
you can just run the new installer, no need to uninstall the previous version 👍
April 23rd, 2024, update 5.00.10018 was released. I suppose that would be the one to use now.
Turbo Tbird
3.8L V6
8.8:1 compression
polished SC crank
Ross custom pistons
Eagle rods
dual valve springs
FMIC
SCT BA5000 MAF
Tial Q 50mm BOV
Walbro 450 HP pump
wbo2_lc1mtxl
ATPCR wrote: 2024 Jun 15, 19:46 April 23rd, 2024, update 5.00.10018 was released. I suppose that would be the one to use now.
yup, that's the one :)
I just downloaded it as well and am using it now too
