1993 F150 4x4 - Trans Tooning
Re: 1993 F150 4x4 - Trans Tooning
That would be the slip ratio function that commands the tcc duty cycle during shift for controlled slippage.
Added a 1st gear hold patch to keep her in 1st with the tcs. Just posted a newer XDF as well.
efloth_240404a4b.bin
(56 KiB) Downloaded 1200 times
Nice! It works and is much cleaner code. It still freewheels on decel. It would be nice to have engine braking, but I can always put it in manual low if that is not possible. I believe b7_Ra2 this is the coast clutch bit but based on the clutch application chart it should already be applied.
91,80,a2            orb   Ra2,80           B7_Ra2 = 1;
Another final step is creating tcc lock/unlock points based on vss.
if its not locking the ccs on decel then you may have obfuscated some code as thats normal operation
tcc scheduling is pretty simple to do
I will double check. Here is the logic in KID2 with named addresses. I am trying to determine if the coast clutch is disengaged in this case.
CCC_CST_CLTCH_CTL_COM1:
9308: b1,08,33            ldb   R33,8            R33 = 8;
# TM_CS_DLY TIMER CONTROL
930b: 31,de,13            jnb   B1,Rde,9321      if (FLG_FRST_CM = 1)  {           # (shift commanded)
930e: 9b,e8,cf,33         cmpb  R33,[Re8+cf]
9312: d7,0d               jne   9321             if (R33 = GR_OLD)  {
9314: 99,06,d9            cmpb  Rd9,6
9317: d7,08               jne   9321             if (GR_CM = 6)  {
9319: b3,e2,d5,38         ldb   R38,[Re2+d5]     R38 = TMCSOD;
931d: c7,e8,fa,38         stb   R38,[Re8+fa]     TM_CS_DLY = R38; } } }            # TM_CS_DLY = TMCSOD
        # (delay coast clutch engagement
        # in third gear to prevent two
        # elements being on at once)
9321: 99,06,db            cmpb  Rdb,6
# TM_CS_ENG TIMER CONTROL
9324: d7,13               jne   9339             if (PDL = 6)  {                   # (PRNDL = 3)
9326: 37,a2,10            jnb   B7,Ra2,9339      if (B7_FLG_CS_CM_a2 = 1)  {       # (coast clutch commanded on)
9329: 3d,a2,0d            jb    B5,Ra2,9339      if (B5_FLG_CS_FRST_a2 = 0)  {     # (1st pass thru)
932c: b3,e2,d4,38         ldb   R38,[Re2+d4]     R38 = TMCSE3;
9330: c7,e8,fb,38         stb   R38,[Re8+fb]     TM_CS_ENG = R38;                  # (coast clutch will be engaged when timer expires)
9334: 91,20,a2            orb   Ra2,20           B5_FLG_CS_FRST_a2 = 1;            # (set first pass flag)
9337: 20,1e               sjmp  9357             goto 9357; } } }
9339: 99,04,db            cmpb  Rdb,4
933c: df,05               je    9343             if (PDL != 4)  {
933e: 99,02,db            cmpb  Rdb,2
9341: d7,14               jne   9357             if (PDL != 2) goto 9357; }
9343: 9b,e8,d9,33         cmpb  R33,[Re8+d9]
9347: d7,0e               jne   9357             if (R33 = PDL_LST)  {             # (4-2 or 4-1)
9349: 3d,a2,0b            jb    B5,Ra2,9357      if (B5_FLG_CS_FRST_a2 = 0)  {     # (first pass thru)
934c: b3,e2,d3,38         ldb   R38,[Re2+d3]     R38 = TMCSE2;
9350: c7,e8,fb,38         stb   R38,[Re8+fb]     TM_CS_ENG = R38;                  # coast clutch will be engaged when timer expires)
9354: 91,20,a2            orb   Ra2,20           B5_FLG_CS_FRST_a2 = 1; } } }      # (set first pass flag)
9357: 9b,e8,d0,33         cmpb  R33,[Re8+d0]
# COAST CLUTCH OUTPUT CONTROL
935b: d7,05               jne   9362             if (R33 = GR_DS_TV)  {
935d: 71,7f,a2            an2b  Ra2,7f           B7_FLG_CS_CM_a2 = 0;              # (verifing a 3-4 upshift, de-energize Coast clutch)
9360: 20,27               sjmp  9389             goto 9389; }
9362: 9b,fd,e8,00,00      cmpb  R0,[Rfc+e8]
9367: d7,08               jne   9371             if (CS_PDL_4 = 0)  {
9369: 99,06,db            cmpb  Rdb,6
936c: d1,03               jleu  9371             if (PDL > 6)  {
936e: 36,a6,15            jnb   B6,Ra6,9386      if (B6_VSFMFLG_a6 = 0) goto 9386; } }
9371: 9b,e8,fa,00         cmpb  R0,[Re8+fa]
9375: d7,0a               jne   9381             if (TM_CS_DLY = 0)  {
9377: 98,d9,33            cmpb  R33,Rd9
937a: df,05               je    9381             if (R33 != GR_CM)  {              # GR_CM <> 4
937c: 91,80,a2            orb   Ra2,80           B7_FLG_CS_CM_a2 = 1;              # (energize coast clutch output)
937f: 20,03               sjmp  9384             goto 9384; } }
9381: 71,7f,a2            an2b  Ra2,7f           B7_FLG_CS_CM_a2 = 0;              # (de-energize coast clutch output.
        # Coast clutch is off hydraulically
        # in 4th. Coast clutch is on
        # hydraulically when PDL = 2 or 1)
9384: 20,03               sjmp  9389             goto 9389; }
9386: 71,7f,a2            an2b  Ra2,7f           B7_FLG_CS_CM_a2 = 0;
9389: 91,01,a2            orb   Ra2,1            B0_Ra2 = 1;
INFER COAST CLUTCH ENGAGEMENT
938c: 3f,a2,07            jb    B7,Ra2,9396      if (B7_FLG_CS_CM_a2 = 0)  {
938f: 71,bf,a2            an2b  Ra2,bf           B6_FLG_CS_ENG_a2 = 0;             # (coast clutch is hydraulically off)
9392: 71,df,a2            an2b  Ra2,df           B5_FLG_CS_FRST_a2 = 0;
9395: f0                  ret                    return; }
9396: 9b,e8,fb,00         cmpb  R0,[Re8+fb]
939a: d7,09               jne   93a5             if (TM_CS_ENG = 0)  {             # (timer expired)
939c: 9b,e8,fa,00         cmpb  R0,[Re8+fa]
93a0: d7,03               jne   93a5             if (TM_CS_DLY = 0)  {
93a2: 3e,df,09            jb    B6,Rdf,93ae      if (B6_FLG_PWR_df = 1) goto 93ae; } }  # (power on)
93a5: 3c,df,09            jb    B4,Rdf,93b1      if (B4_FLG_SFT_MDN_df = 1) return;
93a8: 3e,df,06            jb    B6,Rdf,93b1      if (B6_FLG_PWR_df = 1) return;
93ab: 3f,4a,03            jb    B7,R4a,93b1      if (B7_FLG_DEL_MDN_4a = 1) return; }
93ae: 91,40,a2            orb   Ra2,40           B6_FLG_CS_ENG_a2 = 1; } } }
93b1: f0                  ret                    return;
My brain hurts. I tried setting TM_CS_ENG to TMCSE3 and it's back to disengaging entirely on decel. Not sure if I'm up against the physical limitation of the transmission or my code is hosed. Either way mission accomplished so thanks for all the help.
Hold 1st patch worked out great towing today. She's got too much timing in her under light throttle above 2500 RPM. Started pinging pretty heavy so I pulled over and stuck it in low range and set wot threshold down to 250 for safety. Pulled fine the rest of the way enriched.
I used the development mandatory tcc lockup code to bypass the factory first gear tcc code. SW_MLK is now read from memory address 77e which is controlled by the patch code now. Lockup at 28 mph and unlock at 20 is hard coded but I made scalars to adjust as needed.
794a: ef,27,28            call  a174             Sub_a174 ();
794d: ff                  nop
794e: 39,42,0c            jb    B1,R42,795d      if (B1_R42 = 0)  {
Sub_a150:
a150: 99,02,d9            cmpb  Rd9,2
a153: d7,17               jne   a16c             if (Rd9 = 2)  {
a155: b1,02,34            ldb   R34,2            R34 = 2;
a158: 99,38,8d            cmpb  R8d,38
a15b: de,05               jlt   a162             if (R8d >= 38)  {
a15d: c7,ee,fe,34         stb   R34,[Ree+fe]     [77e] = R34;
a161: f0                  ret                    return; }
a162: 99,28,8d            cmpb  R8d,28
a165: d6,04               jge   a16b             if (R8d < 28)  {
a167: c7,ee,fe,00         stb   R0,[Ree+fe]      [77e] = 0; }
a16b: f0                  ret                    return; }
a16c: b1,06,34            ldb   R34,6            R34 = 6;
a16f: c7,ee,fe,00         stb   R0,[Ree+fe]      [77e] = 0;
a173: f0                  ret                    return;
   Sub_a174:
a174: 3f,e0,04            jb    B7,Re0,a17b      if (B7_Re0 = 0)  {
a177: c7,ee,fe,00         stb   R0,[Ree+fe]      [77e] = 0; }
a17b: b3,ee,fe,42         ldb   R42,[Ree+fe]     R42 = [77e];
a17f: f0                  ret                    return;
why not just use the tcc lock and unlock functions?
I figured this was easier than trying to decipher The first gear tcc functions. I didn't dive into it much but it's very different than the other gears.
