EEC V file conversion
Re: EEC V file conversion
Ok. I will finish up with the sca commands first. I started a bare dir file and started just inputting the sca commands that I needed to get the Bin to disassemble completely. Still not all the wat through with that. I will look into the lookup subs. Hopefully It will get me further along. I posted the bin and dir file in a post above but I will post it again later this evening after I get the dir file cleaned up a bit more. Should be a couple more hoirs and should be able to post a fairly cleaned up dir file to go with the bin file. Thanks again for all the advice and help!!! I really can not thank you enough!!
This is the latest I have.
- Stock_EKO2_256k.zip
- (346.92 KiB) Downloaded 1118 times
Thanks for the latest.
DO NOT;
* Command scan on the DATA in bank 1. Bank 1 is primarily data. Scan is for code.
* Command code on the DATA in bank 1. Bank 1 is primarily data. Code is for code.
* Leave latent scan and code commands in your DIR. Delete them if they do not produce valid code.
* Copy and paste duplicates into your DIR.
Put aside your current DIR's and start from a blank empty DIR.txt file. Too many errors added.
Search the LST for ??? to find undisassembled binary.
Add the LU subs outlined below. See if they work before proceeding.
Add scan commands for Banks 0, 8 & 9. Confirm they all work, giving valid code.
Post that DIR, don't add anything else yet.
Lots of scan commands required, do you think it would be easier if you could scan a range that automatically restarted the scan after each return?
This is the first lookup from MSG, SAD has overlooked a number of them.
I referred you to the RZASA DIR posted in this thread previously, these are the lookups you can match up with OMAE2.
You can also look at what I did for your EQE3 DIR VS RZASA.
From this screen grab, you can see they match off RZASA 92a2e <> OMAE2 826AD.
Put the lookup subs in OMAE2 dir and change/rename the addresses.
Looking at your previous example and the comments from the rzasa LU dir commands above;
Ponder the above, we can get deeper into how Fn and Tb sizes can be worked out after you do the scan and LU DIR.
DO NOT;
sub 82895 "UUYFuncLU_82895" $ F uuyflu 36
##### Function Lookup Subroutines: R36 Fn_Addr Reg, R38 Input Reg, R3C output Reg
SUB 92A2E "SLU92A2E_SUYFn" $ F suyflu 36 # Undiscovered by SAD4.07.16
SUB 92A6C "SLU92A6C_SSYFn" $ F ssyflu 36 # Undiscovered by SAD4.07.16
SUB 92AAA "SLU92AAA_USYFn" $ F usyflu 36 # Undiscovered by SAD4.07.16
SUB 92AE8 "SLU92AE8_UUYFn" $ F uuyflu 36 # Undiscovered by SAD4.07.16
SUB 92B26 "SLU92B26_SUWFn" $ F suwflu 36 # Undiscovered by SAD4.07.16
SUB 92B62 "SLU92B62_SSWFn" $ F sswflu 36 # Undiscovered by SAD4.07.16
SUB 92B9E "SLU92B9E_USWFn" $ F uswflu 36 # Undiscovered by SAD4.07.16
SUB 92BDA "SLU92BDA_UUWFn" $ F uuwflu 36 # Undiscovered by SAD4.07.16
SUB 92C16 "SLU92C16_**YFn" $ F uuyflu 36 # Un/Signed In, Un/Signed Out
SUB 92C62 "SLU92C62_**WFn" $ F uuwflu 36 # Un/Signed In, Un/Signed Out
###### Byte Table Lookup Subroutines: R3C Tb_Addr Reg, R34 Column Input Reg, R36 Row Input Reg
###### R38 Column Quantity Input Reg, R3C Unrounded Output Reg, R3E Rounded Output Reg
SUB 92D8E "SLU92D8E_Y16SYTb" $F sytlu 3C 38 # Byte Inputs *16, Signed Word Out
SUB 92D93 "SLU92D93_Y16UYTb" $F uytlu 3C 38 # Byte Inputs *16, Unsigned Word Out
SUB 92DA0 "SLU92DA0_WSYTb" $F sytlu 3C 38 # Word Inputs, Signed Word Out
SUB 92DA5 "SLU92DA5_WUYTb" $F uytlu 3C 38 # Word Inputs, Unsigned Word Out
SUB 92DF3 "SLU92DF3_yTb.Interpolate" # Interpolate 4 byte cells to find Control Value Pass 1 & 2
SUB 92DF7 "SLU92DF7_yTb.Interpolate" # Interpolate 4 byte cells to find Control Value Pass 3
###### Word Table Lookup Subroutines: R3C Tb_Addr Reg, R34 Column Input Reg, R36 Row Input Reg
###### R38 Column Quantity Input Reg, R3E Output Reg
SUB 92E33 "SLU92E33_Y16SWTb" $F swtlu 3C 38 # Byte Inputs *16, Signed Word Out
SUB 92E38 "SLU92E38_Y16UWTb" $F uwtlu 3C 38 # Byte Inputs *16, Unsigned Word Out
SUB 92E45 "SLU92E45_WSWTb" $F swtlu 3C 38 # Word Inputs, Signed Word Out
SUB 92E4A "SLU92E4A_WUWTb" $F uwtlu 3C 38 # Word Inputs, Unsigned Word Out
SUB 92E8E "SLU92E8E_wTb.Interpolate" # Interpolate 4 word cells to find Control Value
07bc2: a1,ae,54,36 ldw R36,54ae TMP2L = FN070C; # Function address R36
07bc6: a0,95,38 ldw R38,R194 TMP3L = N_RPM; # Input Reg R38
07bc9: 10,08 rombk 8
07bcb: ef,8b,ac call 82859 Sub_82859 (); # Fn Lookup Subroutine
07bce: a0,3c,34 ldw R34,R3c TMP1L = TMP5L; # Table column input R34 = Function Out R3C
07bd1: af,e8,60,2a ldzbw R2a,[Re8+60] TEMP3L = ACPRES;
07bd5: a1,20,94,36 ldw R36,9420 TMP2L = 9420; # Function address R36
07bd9: a0,2a,38 ldw R38,R2a TMP3L = TEMP3L; # Input Reg R38 = ACPRES
07bdc: 10,08 rombk 8
07bde: ef,78,ac call 82859 Sub_82859 (); # Fn Lookup Subroutine
07be1: c0,36,3c stw R3c,R36 TMP2L = TMP5L; # Table row input R36 = Function Out R3C
07be4: ad,06,38 ldzbw R38,6 TMP3L = 6; # Table column count
07be7: 45,b4,10,fe,3c ad3w R3c,Rfe,10b4 TMP5L = Table_193fc; # Table address
07bec: 10,08 rombk 8
07bee: ef,31,ae call 82a22 UYTabLU_82a22 (); # Tb Lookup Subroutine
07bf1: 08,02,3c shrw R3c,2 TMP5L >>= 2; } # Unrounded table output R3C>>=2
07bf4: c3,e2,64,3c stw R3c,[Re2+64] [112e4] = TMP5L; # Store result to RAM
ABSOLUTELY!!!!! I am still adding SCAN commands that I am finding as I go. I will start another DIR file as instructed. Thanks for the advice. Maybe I got a little distracted because I started with an existing DIR file for an older version of SAD. Makes sense to start new.Lots of scan commands required, do you think it would be easier if you could scan a range that automatically restarted the scan after each return?
I have a side questions that probably won't matter too much anymore, but I used SADX to disassemble the BIN and added the struct and function commands to my dir file and got a weird error that I can not find a solution for in the DOCS.. Can you please elaborate, for future use if needed? Thanks
struct 125c3 25c3 :Y X << Warning - Radix missing, Hex assumedWhat is Radix?
Here is my Dir file with Sca commands and Subroutines done. I think?????? LOL
- EKO2_Start_over.zip
- (305.95 KiB) Downloaded 1228 times
Thanks.
Love your enthusiasm, jumping at structures before the code is even sorted. Don't put it in your DIR at this point.
Why do you want to define a 1 byte structure?
Radix is number system base.
Now for the minority part of Bank 1, what do you make of this and why?
RTFM wrote: X <D> 2,10,16 Print radix = bin, decimal, hex X <D>.<D> for decimal places
1db53: f2,98,74,00,d7,16,a0,ed,48,64,48,48,d3,03,bd,ff ???
1db63: 48,88,93,48,d1,06,c0,93,48,91,10,5b,f3,f0 ???
Looks to be a Subroutine to me. It starts with f2, which is the opcode for push(psw), and ends with f0, which is the opcode for return.
The structure I posted was generated by SADX. I ran the Bin in SADX without a dir file hoping it would pull out some things that SAD may have missed. I transfered them over to my previous dir file and that was just one of them. All of them I transfered had the same error. So I was curious what was "wrong" with the structure commands from SADX that SAD did not like.
You have noted in DIR that this is suss, but left the command SCA 8f8d8 in place.
Why do you think it more likely to be code than more words?
Have you searched for 8f8d6 and f8d6 to find the code referencing the word and determine if it might reference subsequent words?
8f8d6: ad,08 word 8ad
8f8d8: ad,08,5a ldzbw R5a,8 wR5a = 8;
8f8db: 11,b8 clrb Rb8 Rb8 = 0;
8f8dd: 22,5a sjmp 8fb39 goto 8fb39;
8f8df: 11 ???
I did. I did all of the SCA commands and then went through and found the Subroutines. Should I have gone through and deleted the SCA commands that happened to land on a defined Subroutine?You have noted in DIR that this is suss, but left the command SCA 8f8d8 in place.
Sorry, I misunderstood, the word suss. Now I see what you are saying. I have not yet searched for a reference for it. That makes sense now that you say it out loud that, that would be the next step.
