EGR module temporarily removed
m-barans
Unread post by m-barans »
So I have a Positive Displacement Blower in place on top of the 4V 4.6. I removed the egr module during the swap and when doing so decided I should splice into the 03 cobra map sensor to the egr baro input circuits. I need some clarification.
Does the egr baro input get used in functions for fueling and engine control?
If not, is there a way to prevent a baro fault code with that equipment being missing temporarily during my engine calibration adjustments?
Re: EGR module temporarily removed
nope
yep just disable it
