When you guys were using the coil connectors for the "Godzilla" coils, what kind of pliers did you use?
https://www.bmotorsports.com/shop/produ ... l5u918efd5
These are the first thing that I found when I did a search.
https://www.temu.com/mini-pliers-ym-too ... 11940.html
Unread post by RinerAuto »
ATPCR wrote: 2023 Aug 18, 18:39 When you guys were using the coil connectors for the "Godzilla" coils, what kind of pliers did you use?
Mean crimpers for the pins? I didn't see anything at the temu link. This is what I bought that helped. I also already had a non-racheting open barrel crimper.
https://www.amazon.com/gp/product/B0BJV ... =UTF8&th=1
I guess I haven't updated this for a bit. The engine runs great, yea there is some drivability things that still need to be tuned and wiring clean up I need to do. But on course and under full throttle this engine is a ripper. It does feel stronger and responds better than with distributor setup. That could also be due to getting a better tune with Decipha than what was on their previously.
My mustang is not a street car. It is mainly used on an autocross course, but there is a lot of on and off throttle. Last year I got the car running in May. Took it to Autocross Week in June where it autocrossed all week along with driving in between each venue for a total of 500 miles. Overall last year with this ECU/ignition setup the car competed is 33 events and racked up 220+ runs.
The best part, for my local club's year end championship I won first in class and first overall, while my girlfriend one first in her class as well.
Yea there is a lot of suspension work done, but without a powerful and reliable engine that would not have been possible. So big thanks to Decipha for pioneering this swap and the tuning. Definitely way more affordable than going aftermarket ecu and gets mostly the same functionality.
Great to hear about the performance improvement. Also great to hear about first in your class in your local club and first overall.
I see the Temu link doesn't work because they sold out of the cheap pliers. Mine from Temu look a lot like what you have.
ADDEDAfter looking at your pictures, I hope my cheap pliers have the correct jaw.
Unread post by dleach1407 »
ATPCR wrote: 2024 Feb 09, 07:59 Great to hear about the performance improvement. Also great to hear about first in your class in your local club and first overall.
Those look correct
I just re-read your thread to see how to properly hook up the Godzilla coils. I do see where you side that you had to swap the wiring on the coils. Would you, dleach1407 or someone have a pic of the coils showing how to wire it? Thanks.
91GTman
Vehicle Information: 1991 Ford Mustang GT
A9L - BE/EA
Unread post by 91GTman »
I still need to do this…anyone else running with Godzilla coils other than riner?
Yep! I'm working with a low fuel pressure issue at the moment. Coils work great.
Ride
Vehicle Information: 2002 Ford AU III TS50, 347ci V8, 3.2LC Kenne Bell. 12SB EECV
Unread post by Ride »
Hi folks, I'm attempting the same conversion to an Aus based Ford 302 (basically an Explorer motor into a sedan from factory) which also runs EECV.
For the wiring of the coils, are they wired in series e.g. +12v to coil 2, then coil 2 -ve to coil 8 +ve, then coil 8 -ve to trigger? Or are they in parallel e.g. common +12v and common trigger on the -ve side?
Well to start with, when you start modding the harness up on top of the intake to power all 8 coils, then all of the coil positives (+), 4 of them pop out spaced apart next to the valve covers. All of the positives are on the same circuit. I tapped each coil power wire into a single power wire per side. I didn't think that the wire gauge was too small for the 8 coil-near-plug arrangement. Only one coil is firing at a time. The trigger wires or negatives are individual. Only 4 trigger wires exist in the Explorer harness. They need arranged such that they pop out of the harness near the positives. I repurposed my rear o2 sensor wires and turned them into the 4 more coil trigger wires needed. Below is a picture of Riner's coils so you see where the coil connectors need to be positioned. You'll be using an EEC-V harness to begin with.
