p1000 RZASA code
p4ndiamond
Vehicle Information: 2004 Mercury Marauder DTR
1997 Mustang Cobra
1998 Mustang Cobra
2021 Mustang Eco Boost
1989 foxbody hatch
p1000 RZASA code
Unread post by p4ndiamond »
Monitors have been good for months. I did have to pull my battery unfortunately. Trying to expedite them back as registration is due yesterday .
How does this code work . Is this Key on engine off Hold brake pedal 5 seconds while holding pedal open ?
Re: p1000 RZASA code
press f10 to read the comments as I've changed that code numerous times over the years.
p4ndiamond
1997 Mustang Cobra
1998 Mustang Cobra
1989 foxbody hatch
Did check through it . No changes.
Seems the two issues i have are the Oxygen sensor heater Test will not complete and neither the catalyst .
Used Forscan to see if i note anything else abnormal . The front two O2 sensors are rapidly turning the heater on and off . maybe 1 time per half second .
No codes in 800+ miles , runs closed loop normally , but refuses to pass this tests . Current draw from front sensors shows 0.96 amps and rears show 0.54 amps .
