SAD Version 5 (alpha)
tvrfan
Guys,
have just released latest SAD, version 5.0.1 to github/EEC-IV-disassembler.
Have added a some new features and done a big tidy up. Most likely still some bugs, but I want you guys to play with it and give me feedback.
This version has new syntax with math calculations and multi bit fields are supported. Can also use a field more than once for printing offsets and such. (old syntax still supported, so should still work with existing command files etc.)
Re: SAD Version 5 (alpha)
Just a quick run with my current dir file and no cmt file gives me a bunch of errors I was not getting with the previous version. Posted up a zip with my files I am using. It is most likely me, but I figured I would report it anyways. Thank you for working in this new version.
- eqe3SADv5.zip
- (411.57 KiB) Downloaded 1466 times
tvrfan
Thanks for being so quick !!
I normally blame jsa for these kind of faults so you have obviously formed a tag team !! (...joking...)
Seriously - I'll check those out against your commands file. I admit I tend to do less testing on the dirs/commands parsing as main thing for me is to try to get main binary analysis working as correctly as possible. There are still some bugs that I know of, but I decided to release it anyway, otherwise I'll be delaying it forever... looks like a 5.0.2 might be out faster than I thought....
LOL. No problem at all. I just figured I would give it a shot while I was on my computer anyways. Like I said, it may just be me or something I am doing wrong. Also, forgot to mention that it doesn't seem to want to work with the drag and drop method. I had to run the exe file and type in the file name. That could also be something I am doing wrong.
Also, it does not seem to pay attention to the byte locations on the SYM commands. Does not label them correctly, also does not break them out in the lst file.
LOL, always important to send the 1st report before TVRfan's screensaver has kicked in!
LOL. Oh man...I just noticed how quick I really was to post that. Sorry. Didn't mean to throw it at you that fast.
tvrfan
Hey, nuthin' like enthusiasm !! No worries. I'm waiting for feedback anyway....
OK - quick scan - some of those commands ARE duplicates, but some are not. Quick check is that each symbol command needs to have something different somewhere in the command, and so from what SAD came back with, couple of examples -
SYM 0007 "ATOD_TIMED_CMD" #UY
SYM 0007 "ATOD_TIMED_RESULT" #UY IS a duplicate - correct
SYM 0015 "LSO_EXP_A" :W #UY
SYM 0015 "LSI_EXP_A" #UY IS NOT a duplicate, so SAD got that wrong....a mistake with read and write somewhere to find....
so some work for me to do....................
Doesn't work at all for single bank KID2 (LHBH1) for me.
A lot of the following:
## word 200a 200f
## Error - PANIC - Row size is ZERO !!
## vect 2010 201f
## byte 2020 2021
## word 2022 2031
## vect 21ce 2269
## vect 22c8 22c9
## word 2350 2351
tvrfan
Thanks wwhite - is that from reusing SAD's _msg file , or from your dir ?? If I can't repro this, I may ask to you send me your dir file, if that's OK? (via PM if you prefer)
To all - I'll collect a few bugs and then fix them together.
A GENERAL QUESTION FOR ALL SAD USERS
jsa reported an error with paths - he told me he uses 'drag and drop' quite a lot on windows. I have tested 'open with' too
and it seems to fail the same way. (I would guess they do the same thing under the covers). This is where my UNIX and Linux background shows up, and I don't use these methods, so I didn't think to test them....
Do you guys use these methods or run SAD via SADwin ?? I am asking because the 'drag & drop' and 'open with' methods typically don't have extra options, (like paths) and this would mean adding a rule that my config file (sad.ini) MUST be in the same place as SAD.exe so that their paths are the same. Everything else, all the bins and listing etc could still be in separate places... I don't want to start fiddling with the Win registry and want to keep same code for windows and linux....
Any comments ?? [Thanks in advance]
I use the drag and drop method. That is mainly because it is fast and easy and I am keeping the files I am working with in their own subdirectories anyways. That being said I am very new at this and my opinion should be the last one you consider. But, drag and drop was working really well on the old version, I was even able to run it on my computer at work from a thumb drive that I have been keeping my files on for now.Any comments ??
