E4OD Calibration Constants
Re: E4OD Calibration Constants
wow man do you mind sharing your xdf. I think adapting kid2 may be easier then adding all of this to a1c
My xdf is minimal, not complete, the dir/cmt(disassembly) is near 100%.
Been playing with the gui version of sad, it can create the xdf from the dir, but not complete either.
No easy way to get complete working xdf.
Tunerpro has an import from csv menu item for xdf, anyone tried that to import into xdf?
I play around with that. I didn't find the kid2 bin anywhere. Please post it and I will work on this.
i never knew about this option. I will have to dig in to it as it could save me a bunch of time making numerous strategies all consistent.
For the sd strats I did a simple find/replace with two columns of addresses on the decrypted xdf. Work would need to be done to add the missing items but the computer does the rest.
efloth wrote: 2023 Nov 21, 12:40 I play around with that. I didn't find the kid2 bin anywhere. Please post it and I will work on this.
Enjoy, all included: .bin, .dir, .cmt, .msg, .lst.
Only a handful of subroutines I have not found.
KID2_all.zip
KID2 .bin .cmt .dir .lst .msg
(358.39 KiB) Downloaded 741 times
This imports into tunerpro correctly It has all 972 calibration constants from lhbh1. Types, address and other data needs to be added. I completed the first item and It does dump into tunerpro. Must first be saved as a tab delimitted txt file. Some Info from the tunerpro manual:
ObjType Integer
0 for Field ID Header
5 for Scalar
6 for Flag
7 for Table
8 for Function
LHB to XDF.xlsx
(52.14 KiB) Downloaded 586 times
Anyone used the SAD806x windows gui?
The developer goes by the name 'thepym'.
Windows executable here: https://github.com/OpenEEC-Project/SAD8 ... master/Exe
It has built in database to save info like what is in the above spreadsheet.
And has built in create XDF file for TunerPro.
I had it working a couple years ago, wasn't perfect.
I'm wondering if using this tool is better for managing multiple bins.
I have used it but it will not but it will not disassemble some bins.
