New Forum
New Forum
The forum is all new as of 15 Feb 2021. The old forum of 8 years took a beating with a php update and failed sql update and wasn't worth the time to salvage it not to mention I've been wanting to revamp it for a while to make it more strategy specific and expedite things. I figured there wasn't much of anything worth salvaging anyway and this was a perfect opportunity to force me to create an all new slate. In any case you won't be able to login with your old info since it no longer exists so all members will need to create a new account. Premium members shoot me a PM and your account will be upgraded if its not caught after registration. Premium members will continue off where they were no problem and a new PM with a link will be sent.
Now for the new-
Langauge packs for russian, spanish finish and a couple others will be added shortly to help those members.
Forums are structured by strategy rather than by ecu type. This will prevent any mix-ups and everything pertains specifically to custom code within strategies isn't confused for non patched strategies. Might not seem like much but will help out tremendously in the long run.
I will be adding content and doing tweaks here and there to make it more up to date and user friendly / efficient. If anyone has any recommendations or requests post here.
Now for the new-
MBSVT
- Vehicle Information: Ford 1992 LX vert AM3 342 CID TFS heads 10.1 CR Long Tubes Holley Systemax Intake Accufab 75mm TB #30 INJ T5 trans 3.73 gears 150 shot NOS
Re: New Forum
Hi I am a old member. I have re register bc I was unable to reset my pass word with my old username.
My question to you is there any way I can retrieve my old post? There was a lot of good information I would reference back to from time to time.
Thank you
MBSVT
Thank you
MBSVT
Re: New Forum
no but if theres anything you need thats not in the write ups just post a thread
woodsman
- Vehicle Information: 1992, Ford, Bronco, XLT, L2L, 9.5:1 306, afr154 heads, shorty headers to Y pipe and 3 inch exhaust. Weighs 5000 pounds, 3.55 gears, 33 inch tires, ZF5-42 manual transmission.
Re: New Forum
Good evening, got registered on the new site, should I look to emails for custom tuning information or will a new thread be started to continue where we left off?
Thanks!
Thanks!
Re: New Forum
its already done you should have a notification
woodsman
Re: New Forum
Awesome, thanks!
Squishy
- Vehicle Information: 1991 Mustang LX 5.0(Stock Shortblock 302), Vortech YSI, Edelbrock Performer (60379) Heads, 1.6 Rockers, F303 (4*A), TFS-R Intake, 70mm T-Body, 4" HPX MAF(Draw Through), #80 SD Injectors, GSS340 Pump(255LPH High Pressure),
Meth (Pre Blower 2x625ml injectors), 2.66 T-56 Magnum, 3.73s
AEM 30-4110 (WBo2-C Transfer Function)
Re: New Forum
I tried shooting you a PM but its not letting me access private messages yet.
roybhood
- Vehicle Information: 1966 Impala SS
461 CI, Tremec TKO-600, FORD A9L pcm, Mass-Flo EFI, Global West tubular suspension, Hotchkiss sway bars, disc brakes, A/C, cruise control.
Re: New Forum
Hi Michael, congrat’s getting the new forum running. I tried sending a PM but the system would not let me due to just signing up. Would you please upgrade my status and send me a link to my tuning thread?
Thanks,
Roy
Thanks,
Roy
motorhead1991
1990 Ford Ranger Custom:
Re: New Forum
I was wondering what was happening. It all makes sense now.
Blocmi
Re: New Forum
Just so you know... the answer to the registration question isn't acceptable if capitalized.
The new forum looks nice and clean, nice job!
-Mike
-Mike
