Rpm's climbing when put into gear
Covers most all fords in the 96/97 model year including but not limited to mustangs v6, v8, cobra, thunderbids, lincoln town car, grand marquis, crown vic and even some trucks and vans.
Squinks
Vehicle Information: 95 F150 | 5.8L 351W | MAF Conversion AHACB/HOG0 | Trick Flow R Intake | Trick Flow 36lb Injectors | Pro M 36lb Calb MAF | GT40 Heads | Lunati Street/Strip Cam |Binary Editor | E40D Transmission | Shorty Headers
Unread post by Squinks »
I am attaching my data log and tune for reference. The truck idles perfect "Blip the throttle rpms come down smoothly" and also drives down the street if you got a clear shot ahead...
Issue is...When I put the vehicle into gear the RPMs shoot up and the truck wants to take off immediately. If I let it accelerate without fighting it the truck will climb up to around 8mph then the rpms decay. The truck will repeatedly do this when trying to sit at a complete stop. I have tried everything to my knowledge of a 2 week binge on Decipha's Write up's, tweaking Dashpot Tables to no avail.
MAF curve is from the flow sheet provided with MAF (Added +5% @ Idle)
Injector Slopes are skewed to 39.50 Fuel Pressure (did my best)
I appreciate anyone curious enough of look into this.
Using Binary Editor for tuning/ Do I make the leap to TunerPro?
Link to Datalog & Tune:
https://www.dropbox.com/scl/fo/11lv0kzn ... imi3e&dl=0
Thanks,
Base Idle Ford Squinks.BEB
(1.19 MiB) Downloaded 1661 times
Squinks
Re: Rpm's climbing when put into gear
Been messing around with the ISC drive multiplier. Am I just not shooting low enough values into that table?
Squinks
Looking further into the tune this morning. Im positive I have some functions in here I have set wrong. Give me time, Give me time I wanna figure this out and not have a hand held to the finish line.
Squinks
Starting from the top. I will keep you updated. Really want to figure this out without needing a hand.
Thanks,
air spark and fuel
see which one spikes when you put it in gear
Squinks
Spike in air,
Tinkering around some more with the tune and doing more research now.
Squinks
TP is shooting from .98 to 1.05 when puting vehicle into drive. Failing TPS? Might as well go grab one.
wiggle the wires to the tps while watching the value. Then do farther down the harness as needed. You may have wiring problem or missing ground wires.
Squinks
Got it all handled! New tps. New Throttle Cable. Voltage is steady when at idle. Time to datalog!
