Deciphas 03 Marauder "Dyshyky"
by decipha » Sat Feb 11, 2017 10:14 pm
Well I just went and picked up the latest addition to the fleet
An 03 Marauder I named Dyshyky (Dye-Shee'-Key)
Bone stock all original and will stay exactly as such
____________________maintenance_________
u joints - june 2018
fan 2018 GT - sept 2018
ac blend door actuator - 10-14-2018
rotated tires, new front hubs, rotors and pads - 11/22/19
blower motor resistor, headlight wiring, grill, belt and tensioner - 01/19/2020
oil changed
04-24-17 34,760
07-31-17 38,580
02-01-18 43,872
02-24-19 53,840
11-02-19 62,571
07-09-20 73,637
by decipha » Sun Jun 10, 2018 11:39 pm
Got a 20k mile all original 03/04 cobra setup complete with blower and all from my friend Chris the owner of the old 49 Performance / Speed Productions out in Jackson / Florence Mississippi.
Will be detuned for 87 octane still but should be a nice little bump in output. Should be around 16psi on stock eaton ~300rwhp or so. About 100 rwhp more than now on 87.
Plan on swapping it in as soon as time allows.
by decipha » Fri Jul 06, 2018 4:33 am
tinted the tails day before yesters
by decipha » Sat Mar 14, 2020 1:26 am
I have her out here in victoria texas and decided to plasti dip the wheels this evening.
<copied from yahoo cached threads> placed here for reference
wheels plasti dipped out in texas mar-14/2020
Re: Deciphas 03 Marauder "Dyshyky"
Unread post by bad86capri »
Hows the marauder working out so far? Ive really thought about parting ways with my mach 1 and getting a marauder. That or an auto Mach 1. Yeah i know im weird for wanting an auto mach over my manual mach.
I started a new job back in 2020. I've driven the marauder maybe twice since then. She's sitting in my backyard right now. I moved her around the other day. No time to tinker. Hopefully in a few years I'll get some free time to swap the engine out.
I didn't realize "Dyshyky" was down. Upgrading the engine?
You missed the OP.
"Got a 20k mile all original 03/04 cobra setup complete with blower and all".
I see now
Turbo Tbird
Vehicle Information: 1993 Ford Thunderbird SC
3.8L V6
8.8:1 compression
polished SC crank
Ross custom pistons
Eagle rods
dual valve springs
NGK BR7EF plugs gapped @ 0.020
Precision 46mm waste gate
3" exhaust w/ cutout
FMIC
SCT BA5000 MAF
Tial Q 50mm BOV
80lb Siemens Deka injectors
modified F-150 4.2 fuel rail
Walbro 450 HP pump
8AN feed, 6AN return
wbo2_lc1mtxl
Unread post by Turbo Tbird »
i love Marauders.. one of my dream projects for a long time has been a 6 speed swapped Marauder with boost, probably a single turbo. too bad they didn't quite slip under the radar as far as collector car prices go, which it looked like they might for a while there, lol... still a relative bargain though, whether as a bone stock driver or something a lot more radical. the one that Cleetus McFarland raffled off REALLY blew my skirt up, even though it was autotragic ❤️
Scaryy_GT
Vehicle Information: 99' Mustang GT
Research & Development Vehicle
wbo2_UEGO
PTP2
Unread post by Scaryy_GT »
Any new year update on the Marauder build?
3 weeks ago vandals broke in and stole my 20k mile steig 3 ported blower along with the lower fresh from sand blasting ready for powder coating
so now its just going to stay stock
its crazy i posted last in nov of 23. I've literally had 14 days off the entire 2024 and worked 90+ days straight twice in 2025.
im about 6 years out on other projects so its going to sit for the foreseeable future. 2032/2033 check back
Scaryy_GT
wbo2_UEGO
PTP2
Dang, crazy to hear about that blower getting stolen! Welp, I’ll try to keep an eye out in market place just incase we see some super cheap blowers for sale.
And wow! 90+ days straight? Sounds like you’ve managed to find your self in an industry where “up time” matters a lot, and any downtime sounds really expensive. That, or you’re the person that comes in when no one else can get things figured out to get going. **Sprinkled with a little bit of thirst for accomplishment.**
