EEC V file conversion
Re: EEC V file conversion
Ok. Thank you. But I’m still a little confused about how that would pertain to a dmr file. But I think that’s what jsa was saying we could come back to later. I’ll download the older version of sad when I get home and start looking through and comparing and see if I can find any similar code using tp_eng first. I’ll post what I find , if I can wrap my head around this a bit more.
Also…not sure how what I posted shows that Jsa posted it. Very weird.
BOOSTEDEVERYTHING wrote: 2023 Oct 25, 17:10 But I think that’s what jsa was saying we could come back to later.
Yes, later.
That is weird, I can edit it.
It's as though you logged in as me.
I'm off to change my password.
I posted that right after I posted the previous post. I thought it was weird it wouldn't let me edit the previous post to ask that question.
I am not able to find the version of sad to download that you said to use on rzasa, can you please post a link?
It was done for SAD 3.07.16B, so run it with that version for now.
It quite likely contains errors, from others sources that have been imported.
unless you meant to say version 4.07.16b?
May have found SPARK_M_B_T?
BOOSTEDEVERYTHING wrote: 2023 Oct 25, 20:07 unless you meant to say version 4.07.16b?
Yes sorry, typo fixed.
https://github.com/jsa2340/EEC-IV-disas ... 07_16b.exe
BOOSTEDEVERYTHING wrote: 2023 Oct 25, 21:12 May have found SPARK_M_B_T?
Paul,
No, I'm not convinced.
Stick to working through TP_ENG for now.
Ok. Just thought I saw something and wanted to confirm. I’ll stick to the tp_eng. Lol. Should there be more occurrences of the tp_eng that I am looking for or just pointers to other functions from tp_eng? Sorry if that’s a silly question. Also, should I be focused on the lst files or the msg files or both?
Found this one. I'm still working out exactly what it is doing, I'll edit this post later if I can figure it out, lol.
Also, where can I find a calculator to figure out that this-[Rec+c8] is [11548]? I have downloaded a couple of hex calculators from the apple app store but cant seem to find one that works well for me. Thanks so much for your help, again.
BOOSTEDEVERYTHING wrote: 2023 Oct 26, 08:10 Should there be more occurrences of the tp_eng that I am looking for or just pointers to other functions from tp_eng?
Consider it unknown, so search for more occurences to prove either way.
LST and the 2 strategy docs I previously mentioned.
Post up the page number from each strategy for the tp_cnt>tp_eng sub.
BOOSTEDEVERYTHING wrote: 2023 Oct 26, 10:31 Found this one. I'm still working out exactly what it is doing, I'll edit this post later if I can figure it out, lol.
Good find.
Post up the DIR and CMT entries for it.
The default windows calculator can be set to programming mode to do it.
