TuNiN n00b Exp -Cpl n00b ?s
entity-unknown
Vehicle Information: 87 Bronco FSB Eddie Bauer w/ 89 Mustang MAF Swap / C3W PCM w/ A9L2 BIN from Decipha / 347 FRPP BOSS Block (Part# M-6009-347) / AFR 165cc heads / 42Lbs Green(Active) & 30Lbs Red(Shelf) Bosch Injectors / CompCams 35-510-8/FW XE258HR-12 / AOD fully beefed up / King 2.5" Suspension w/ Bump Stops / 5.13 Gears Front/Rear on Auburn Pro LSD / 35"(Active)/33"/37" Tires / Very Custom Built Bronco aka Bonnie
Unread post by entity-unknown »
I found why I couldn't push the pedal all the way down ;) It's just always been this way but it's because my USB cable from my laptop in early 2000 was rolled up under the carpet and worked it's way under the pedal at some point. The laptop was my MP3 player before we had MP3 decks and iPods/etc.
:D I moved that and now I can get about 725~ AD counts for TP when I mash the pedal so I adjusted THBP2 to 725 from 750 and now I can engage WOT.
The other restrictive point I have on the throttle is my AOD TV/kickdown cable. The only resolution there is to remove the spring inside the AOD and replace it with a weaker one or heat it up to weaken it. Heating is not an option cuz that could cause it to break one day and that's no bueno inside the AOD. It's not too bad and always been that way, but def about twice the effort or more without it. I've had 3 AODs and they've all been the same so it's just normal.
Goals Accomplished: I took Bonnie out on two extended trails, about 7 hours of low speed trailing with hills, and my laptop did not die during either trip! The POS usually dies when I hit a bump but it's getting replaced and I guess it knows it.
I was able to data log everything and it all went perfectly. My lambses are balanced around 1.00, engine temps are good, and just no issues at all. The big change is the new exhaust specifically the JBA headers that DO NOT leak.
I was able to get to one of the trails which is up hill for several miles at highway speed and I was able to accel a bit but more importantly maintain speed w/o extra effort in 4th gear vs. havin to kick down to 3rd. It's 65 MPH speed limit and most drive 70+ and I was able to maintain 72-73 which is what I usually had w/ 4.10 gears, the 302 HO roller/MAF and 31s/33s. Once I review the logs and tune things I'm sure I can get more out of it like I have with the other hill and freeway tuning I've done. It's not easy tuning the higher MAF AD counts legally on the street and the highway is a bit far from me ;) I prefer to enjoy my tuning fuel costs as well vs. sitting on a dyno roller in a garage even if it's goin to take me longer ;)
Coming back home after the trail, doin 78 dowhill was easy and had to use the brakes/throttle control to keep it reasonable and prudent ;) The rest of the way is up/down hills too and just a smooth ride all over.
I'll continue on and see what else I get but lovin this RPG level up style / unlocking new achievements experience in tuning :D
Unread post by red5.0fogger »
You could try and replace the TV cable. something could be wrong with it causing extra friction. I've had it happen with clutch cables.
entity-unknown
Thanks Red! Pulling it directly from the shift shaft it's the same tension as up at the throttle. It's a heavily built AOD that's got about 2,500 miles on it (about 500 more than the engine) and I'm sure the spring is new. It sure has plenty of tension. It was noticeable too when I put in my shift linkage since I had to swap that over since Monster doesn't give the truck linkage for the AOD.
On a side note, somethin went wrong and it's dumpin in fuel and flooded itself. I watched the lambses keep climbin. It's happened a couple times when I pasted my MAF table in wrong so like 200 AD count values go in the 0 AD count column :\ If it doesn't stall out and I can start it, I just put in a proper MAF table and it'll chug back to life and be normal. If not, then I've pulled the spark plugs, let it air out for an hour or two, and then it's good to go. This time (maybe I just didn't pay attention before) the Lambse values kept climbing once it finally hit CL which is struggled to do. I had a f'it moment and set the MAF table to about half so dangerously lean, probably can't even run to see if the Lambses would keep climbing and they did at the same rate. At about 1.20 it's clear it's game over for that round. If a restart doesn't even attempt to fire, it's pull the plug time. Got about 7 experiences w/ this so far.
In fear of messing w/ the MFA/DFSO to run a lean cruise and maybe I really did do something bad and new fancy engine I built myself, I prob should do it; I did a leak down test cuz I had some carbon on the plugs. I also used up about 1.5 quarts in say the last 1,000-1,500 miles which is after the 500 mile break in period (I have no speedometer/odometer cuz I don't want to replace my VDO and shift by RPM/traffic works well enough for the last 20 years plus I live on the edge of town so these are guestimates and likely exaggerated a bit )
So I have 2~% compression loss on all 8 cylinders (not guestimates :D ) so clearly Ford Racing and AFR builds their engines / heads proper which was clear when I got it with every measurement that mattered paint marked inside of the engine and I had to tear down the AFRs to drill out the head bolts to 1/2" so I got the full experience of their precision esp. their valve springs. I guess I did something right building it too and clearly I've done nothing terrible with my tune (yet) :)
Since I like sharing my dumb ass moments so other's can learn from my mistakes and I can actually admit when I f' up... I learned how much torque a very well sealed piston/cylinder and 100 PSI can generate.... Didn't occur to me it could rotate the crank but it sure did. I also left the socket wrench on the crank so it rotated the wrench into the transmission cooler line with enough power to pull the line out of the -AN fitting :D Now I know and the 90% remaining of that battle will be putting that -AN fitting back together cuz I made those lines nicely and hopefully I don't have to replace it (it's the return line so there's one silver lining) ;)
So now to figure out WTF went wrong here but I'll figure it out.
The logs show the PW ( I REALLY LOVE having logs) for the injector stuck open so I figure that's where I get to start if putting it back together doesn't magically fix whatever happened (fuel evap'd from cylinders/plugs if it's "magic"). Not enough info yet to go off of. Just more BS fun adventures in tuning ;)
The highlight was really the note worthy moment to post about ;)
sounds like the fuel pressure regualtor diaphram ruptured
pull the vac line off the regulator and give it a whif
entity-unknown
I did and it had no smell. I have a fuel pressure gauge on the rail and it holds a good steady PSI and takes hours to bleed off. New Motorcraft FPR when I built this last year and my old FPR died :)
ECM checked out, spark plugs were dirty from when it ran super rich but cleaned those up. SO I load up Dashboard after putting everything "back together"... I saw the IMAF last time at 18 but didn't pay attention to see if it was flipping, I figured that was from surging cuz it does that BUT it does fluctuate w/ a "normal" surge. This time I was less panicky and got a good log set. The IMAF was stuck at 18 the whole time and various stats like RPMs, timing advance, others had this VERY consistent wave....
I disconnected my MAF to verify the pin out for the intake I'm building and I may swap to the newer style MAF connector vs. my 89 Mustang oval style..... I lightly connected it back in cuz no logical reason I can come up with....
"Plug in your MAF sensor you f'in idiot!" :D Plugged it in, she's happy! But hey, at least I did a compression leak down test, learned somethin, and got to set aside some questions like "how is my engine really running in the cylinders?", spark plugs are nicely cleaned up and connections are tightened, oil changed, so it was actually worth all that extra effort and as usual hopefully someone learns somethin from this ;)
Attached are the oil pressure, inline water temp and fuel pressure gauges I have. OP gauge is tee'd in with the OP sensor on the side of the block, and the water temp gauge is inline just after the water pump. I also have a TV pressure gauge up top for the AOD.
you obviously didn't dial in my custom fn1036 table
I have a histogram in tunerpro that populates the data and you just plug the actual value in from the histogram.
With fn1036 dialed in properly you may not have even known if the maf was plugged in or not as it would have run very similar.
entity-unknown
Nice and 100% correct, I hadn't looked up which table it was yet so no I've never dialed this in so Thank You for sharing that and I'm bout to a point where I can do those tables :) Ideally I shouldn't forget to plug the sensor in tho so I didn't mind it running like shit and makin me feel like an idiot and now I know what to expect if I forget again and don't have the laptop/QH ;)
I didn't want to touch any fall back tables yet until I get the MAF dialed in which I have several times, but then I make a major change like the exhaust and get to rinse and repeat. Like now I just opened my hood vent slots and reduced my ACTs by 20-30* average but the MAF re-tune goes WAY faster now too. I have two more major changes left for the intake which is going to 104mm (4") at the smallest point of the intake since I have a 52mm x 2 throttle body (302 truck TB). Currently it's all 3" with a 55mm MAF body choke point that all came with the truck when I bought it way back when.
I have a straight piece of 4" Aluminum pipe for the main intake piece for the MAF sensor and I have to design/3d print it's mount. I designed a Y-connector I just 3d printed to connect the 4" pipe to the 52mm TB tubes. Then I need to build an air box and plenum around the filter for the two hood vents to force air into the air box. The connection tube for the hood vents to the box has a built in ACT so I'll use that to relocate the ACT off the intake manifold finally as well and keep the ACT on the manifold as a plug / backup connection. The air box will be removable so I can just run the filter without the ram air hood vents too so it's all modular. Fun stuff!
maf has no affect on actual load. exhaust would be minimal.
injectors heads cam and intake will dictate the failed load
injectors theoretically shouldnt so long as the data is accurate
entity-unknown
Thank You Decipha :) Injectors seem to be proper overall. New sealed Bosch 42lbs only ever used in this engine with Ford/your data. I want to adjust my break point, at least I think it's something I should do in time since around 400 AD counts there's the noticeable shift in fueling I believe you see when your break point occurs and has some room to grow but it's nothing that needs to be done "now"... I figure the injector slopes could be tuned a bit too but the MAF is good enough till I finish the intake and ACT relocation.
So the "Unplugged MAF Tables" Comprehension Test...Let's see how well I do...
VMAFO1 Noisy MAF Patch (FN1036):
So looks like I need to enable the patch to begin with? This will be the first patch I apply so some comfort "Yes click "Apply Patch" and read the rest of my notes in "Parameter Comments", but overall out of the box it will prob work better than without it enabled" :) I gather this is something you added in the space you carved out of the "not so useful" code space?
Enable Extended FN1036B Table:
It's Patched already but I gather this simply allows the table to exist/be populated in the running code otherwise it has no relevance to it actually being used, that's the first Patch mentioned above.
I also reeeed DO NOT MESS WITH VMARPM unless I REALLY know somethin which I know nothing about this except it's set to 16k RPMs by default i.e. unobtainable unless something bad happens and pegs your tacho signal so effectively disabled/safe to enable the patch.
"VMAFO1 (I'm sure that's an "OH/O2/KOEO" not a "ZERO" but fonts and there's nowhere to highlight/copy/paste from to figure it out ) MAF Min Volts:"
I see the default is 30 AD counts so i.e. this would have enabled the FN1036/FN1358 fueling table when I had the MAF disconnected and it ran like shyte because the static AD counts w/ the MAF disconnected was 18 so below 30. So I gather this is where you suggest it might've just ran fine or at least better than w/o?
VMAMAX - is a test function for KOEO so the code reader gets what it expects to see, so just leave it as is.
N_TP_FN1036_HegoErr Histogram / History Table:
I see in this table I want to move this to Fuel_Err_Ego1 since I only have the single/mono O2 sensor for the Z Object. Since this is based on the MAF/AD output, I'm not sure how this table ties in...? Maybe this is the table I'd watch IF I unplugged my MAF or it failed and I had to see how it's doin when the FN1036/FN1358 table is active since it seemed I was still getting O2/HEGO data w/ the MAF unplugged?
N_TP_LOAD_GUFX Histogram / History Table:
This looks like this histogram relates entirely to FN1036B/FN1358 and can ALMOST be copy/pasted from the Histogram to the table? I can certainly edit the table to make that easier but I like the resolution the Histogram has and I can skip the rows as needed. I gather this is the Histogram you're more referring to?
SP**FN1036B - Decipha Inferred Load (FN1358):
I see as w/ the Histogram comment, to tune this table, I'd want to get the relative values from the Histogram and update this table accordingly?
My loads are fairly different as the TP scale grows but I gather that's the point of me tuning this.
If I average across the Histogram TP counts from a current log just to give a rough example I get:
TP AD Count Load Average
0 0.175
20 0.216
40 0.236
60 0.321
80 0.35
100 0.432
120 0.488
140 0.53
160 0.578
180 0.619
200 0.615
250 0.644
300 0.705
350 0.723
That's the TP values from 0-350 populated, I didn't have a higher TP value populated from this log I pulled and not important. The scale in the FN1358 table has say above 1.00 across the entire 300 TP AD count range vs mine is 0.705 average so very different, again using the average across the entire RPM range just for illustrative purposes since the tabular is granular for RPMs.
So I gather to tune this table for say the AD count range for just 350, I enter the table values relative to the given RPMs I got which are the "Running Average" for the "N_TP_LOAD_GUFX" Histogram so for this log example I have:
RPM: 2250 2500 2750 3000 3250 3500 3750
TP: 0.752 0.758 0.730 0.714 0.707 0.700 0.698
So enter those in the respective spots and more or less I'm done or at least much better off than before (assuming this function is enabled/Patched) ?
Did I pass or fail the Comprehension Test? :D
That's it, plug in the average load value from the gufx histogram for the rpm and tprel in your table. That simple.
