'95 GT stock 302 Vortech V1 FLOODING no start
Re: '95 GT stock 302 Vortech V1 FLOODING no start
Cool, so now where are you at with it? Does it idle?
dakotagatlin
- Vehicle Information: 1995 Mustang GT Vert; Stock 302 bottom, GT40p Heads, 1.7RR, Explorer Intake
1995 Mustang GT; 302 bottom(milled crank for larger bearings), E7 heads, Vortech V1, 80lb Siemens, Explorer Intake, Aeromotive1000 Regulator
I was able to get it to idle. And some part throttle. Had a couple other issues arrise. Maf is fluctuating up and down in 22-34 point swings.
I tried reclocking, to not much avail. Currently back at work,I only get time on weekends
My maf is done in volts, but i think it's to be expected to move a bit. Decipha likes to have plastic screen before and after the maf sensor, it straightens out the airflow and helps settle the reading. (household plastic window screen. )
