90mm PMAS range
SOAB_465
Vehicle Information: 1998 Ford Mustang GT 5 speed box code BAI1, CRAI8
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
- tuning with TunerProRT
PLX Wideband
GM 3bar MAP
90mm PMAS range
Unread post by SOAB_465 »
Just out of curiosity, what could cause MAF counts to be much higher than expected?
I have a hitachi 90mm stock replacement MAF, in the stock 03/04 cobra airbox. I'm getting 1000 AD counts at ~50.3 lbs/min. I'm pretty sure t's not a problem with injector slopes, it's definitely not making the power to peg the MAF (350ish WHP on a dynojet through a 5 speed), it's just reading high for the air it's passing.
k constant is 30, SARCHG is set to 281 CID. green Ford 42lb injectors, slopes directly from the reference files and seem to behave perfectly - seeing 0.58 DC at 27 MHz.
thanks in advance for any help
Re: 90mm PMAS range
Unread post by red5.0fogger »
50 lbs/min is is about 500 hp. I think you mean 50 kg/hr... Around idle speed or just off idle?
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
Re: 90mm PMAS range
No it's lbs/hr. It's a twin screw supercharger setup, TunerPro is calculating about 470 hp in the data log, but I thought these MAFs were good for a bit more than that.
The low output to the tires is another question I have, but it's fun enough for now so I'm just driving it.
Re: 90mm PMAS range
nope, that's about all its good for
