With my RZASA xdf having over 3,400 parameters its becoming cumbersome to navigate in tree view so figured I'd need to start utilizing the levels to make it easier on myself. This is what I came up with.
LEVELS
10- console pids, scaling - hidden patches, unused normally unchanged stuff
9 - obd2, custom code patches, hardware limits
8 - closed loop algorithms, base tune stuff thats hidden normally
7 - hardware config, fail safe, additional limiters, backflow, ipsibr related
6 - mbt, sarchg, scaling used commonly, etc, vtc, tseif - next level intermediate stuff but not normally needed
ABOVE 5 IS GETTING AWAY FROM TUNING AND IN TO CONFIGURATION
ADVANCED USERS ALL THEY NEED
5 - spark retard, knock sensor, stoich,
4 - perload, fn1036, imrc, startup enrich
3 - dashpot, dfso, isc mul
2 - trans shifting, tcc
1 - maf, bdl, base fuel, rev limiter, axle, driver demand
Posting here for myself to have a reference. Won't be in the other xdf's til 2025 or so.
TunerPro LEVELs - RZASA 1st
mechanicalmatch
CVAF1
4R70 3.08
Re: TunerPro LEVELs - RZASA 1st
Good work
How hard is it to re-organize the tree view?
if you do two parameters a minute, 4 hours a day 3x a week itll take about 2 1/2 weeks
I assume this does not change the bin order?
