Rev limiter scalars having no effect
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
- tuning with TunerProRT
PLX Wideband
GM 3bar MAP
1998 mustang GT. 2valve 4.6 with original wiring harness and ECU. I have set NLMTLO_1, ~NLMTHI_0 and ~NLMTNEUHI_0 all to 6600 to 7000, but the engine hits a fuel cut at 6050RPM. does it both in gear and in neutral.
Is there another rev limiter or has anyone else come across this situation?
Thanks,
Paul
Thanks,
Paul
034v
Re: Rev limiter scalars having no effect
MNPIP8 to ZERO done yet?
11,250,000 / (1/2 # of cylinders × max rpm)
Or
11,250,000 / (4×7000)
Or
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
CRAI8 xdf doesn't have MNPIP8 as far as I can tell, I wonder if it's hidden or mislabeled
FNRPM_LIM its the rev limiter function for torque modification
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
oh ok, that one isn't identified in CRAI8
just posted a new xdf has it in there for you
enjoy
enjoy
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
That's awesome, thank you so much!
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
I see now how the soft limiter works, is it safer to use the NLMT scalars on a boosted application? Does FNRPM pull fuel or timing?
either is safe no issues there
why are you intending on hitting the limiter?
the objective is to shift before you bang the limiter
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
Ha ha I know that's the goal, but when it doesn't hook up in 1st things happen too quickly for me. I'm still getting used to driving it with the twin screw, and don't want to make an expensive mistake before i get good at it.
