EFI-SD36e
Re: EFI-SD36e
nope rather useless
Re: EFI-SD36e
I've been using the internal parts from the older EECs for other electronic projects.
There's a few larger diodes in the SD36 that I've taken out to repair a Lexus Nakamichi amp.
pcwizzy37
- Vehicle Information: 1991 Ford F-250HD XLT Lariat 7.5L V8 EFI, E4OD, EEC-IV SD36E S0J
1991 Ford F-250 XL 4.9L i6 EFI, ZF-5, EEC-IV SD40A E1M
1995 Ford F-250HD XLT, 7.5L V8 EFI, EEC-IV SD48A DOE0, manual swapped
Re: EFI-SD36e
Sadly, I don't have it on the bench anymore. I suggest finding a EFI-SD48E ecu as they are plug and play on the 91. DOE0 box code is for the 7.5l and e4od. You could then run the strats already available for that series of ecu if you want to tune it.
pcwizzy37
Re: EFI-SD36e
I would much appreciate a strategy for the 7.5L E4OD if anyone already made one.
pcwizzy37
Re: EFI-SD36e
I think the SD48e PCMs are all base calibrated for the F3TE heads, my engine still has E7TE heads on it. I have a 1992 PCM that is still SD36. SD36 seems to have alot more robust capacitors too.
pcwizzy37
Re: EFI-SD36e
Also my '95 has the DOE0 box but it only works on '95+ E4OD transmissions (With the different solenoid pack plug too)
Re: EFI-SD36e
I have used SD48e DOE0 on a 91 and it worked flawlessly. The Solenoid pack change only moved diodes to the ecu. Having multiple diodes in the circuit will not create any adverse effects.
