TunerPro RT glitch?!
m-barans
I downloaded the latest version of TPrt and found when I loaded any RZASA bin file I chose, the values shown for MAF air mass and Injector values were very different (higher) than what they show with an older version of TunerPro RT. Automatic scaling percentage was different too. Am I missing something here? I’m guessing I’m not the only one whose ran into this. Any support is appreciated and thank you.
motorhead1991
- Vehicle Information: 1990 Ford Ranger commercial:
1990 Ford Ranger Custom:
Re: TunerPro RT glitch?!
I've yet to see this. Try a different bin to verify that yours isn't corrupt.
you need to input your high slope and enable dma datalogging
i updated the address last year
m-barans
I executed those 2 steps and things are now looking familiar again. Thank you much -
