Curious as I just found out there was a few professional drivers that stop by the forum every now and again.
Is anyone here a pro driver?
If you go to the track at least every other week your probably a pro driver too I'd say.
Professional Racers Roll Call
Blocmi
Re: Professional Racers Roll Call
I'm definitely not a pro, by ability or budget :)
But I do spend nearly every weekend from April to October at a track drag racing... And every Wednesday too...
One of the few using EFI, probably the only using a factory computer.
I'm from Newington CT. Where are you located? What track do you mostly go to? - George
Blocmi
Colchester CT. I mostly commute to Lebanon Valley.
shit yall are practically neighbors
