Does a lower compression engine require more crank spark?
How does crank spark effect crank load?
Cranking
m-barans
Re: Cranking
No
It doesnt.
It doesnt.
m-barans
Re: Cranking
If cranking spark is null then that leads me to believe that more throttle body bypass mass air may be needed along with some additional enrichment. I will try that out
m-barans
Re: Cranking
Update: Adding additional crank PW (Load) has helped. I opened the throttle bypass more during cranking and In addition: I reduced returnless pump prime time to almost nothing. I am getting better “torch-offs” now
