What da prolem is? VIII
Off topic subforum for just goofing off and wasting time on possibly fun non-sense
Unread postby decipha » Thu Dec 04, 2014 9:42 pm
alright this is an easy one
said vehicle is a 96 crown vic 4.6L w/ 4r70w trans, completely bone stock
vehicle runs fine but has a random misfire at idle and very low loads, its a random misfire but occurs on both banks of the engine and at random times while idling and cruising. Has no rhythm to it and sometimes you can go days without a single hiccup.
The owner of the vehicle says it's not really an issue just a nuisance and the vehicles runs fine otherwise. WOT is nice and strong and the engine feels very responsive. The engine is completely bone stock with 140k miles on the clock but a complete full tune up was done less than 15k miles ago. The problem has persisted since 90k miles and nothing has seemed to helped it. When it first occurred he brought the vehicle to the dealership (car has always been a dealer only vehicle for maintenance) and they replaced the following. Note that since the issue arouse 50k miles ago the following has been changed to no avail
ECU is throwing no codes
timing chain and tensioners
plugs
wires
coil packs
cam and crank sensors
pcv valve
fuel filter
fuel pump (went bad at 130k)
air filter
maf sensor (mechanic changed originally thinking it was the problem)
EGR valve and flow sensor
The vehicle has been to 3 different ford dealerships and 6 different independent highly regarded repair shops that specialize in fords. The issue was never resolved. I was contacted by a friend of mine that owns a local repair shop to come check it out, he had the car for 2 weeks and was completely baffled but was determined to get it fixed.
I come over and first thing I do is plug in to see whats going on in the ecu, everything looks perfectly nomal but when the engine misfires i can see that hego go lean and the lambse richen up to compensate then come back to normal. I see its occurring on both banks of the engines and there's no repeatability to it, it's a completely random misfire and when you rev the engine up it doesn't do it.
So I get to snooping under the hood and voila!!! The problem is staring me right in the face.
anyone want to take a stab at it?
Name: Michael Decipha Ponto
06 Chrysler 300 AWD - Sharifa
Re: Cause of Carnage VIII
Unread postby YaBoyHalle » Thu Dec 04, 2014 10:54 pm
this actually happened to me for a loooong time. coil was too weak, couldnt gap the plugs wide enough. loose alternator mounting, wiring. loose engine/bat ground.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Thu Dec 04, 2014 10:59 pm
nope all that was checked and/or replaced no issues there
Unread postby ranga83 » Thu Dec 04, 2014 11:36 pm
O2 wiring melted/broken but still making contact most of the time?
ranga83
Vehicle Information: 1996 EF Falcon 4.0 inline 6, 4TAD ecu, tunerpro, and moates q/h
Unread postby decipha » Fri Dec 05, 2014 12:08 am
nope all's well there
Re: What da prolem is? VIII
Unread postby decipha » Fri Dec 05, 2014 1:29 am
as you can see, i changed the name of the game to be more accurate
cause of carnage indicates damage ensued
Unread postby red5.0fogger » Fri Dec 05, 2014 5:57 am
On a side note: if there is a missfire detected at cylinder x, How does the ecu figure out which cyl it was?
Premium Member
Unread postby decipha » Fri Dec 05, 2014 7:40 am
by the rpm drop when that cylinder reaches tdc
Unread postby red5.0fogger » Fri Dec 05, 2014 11:05 am
Is it a tiny vacuum leak? I heard of explorers sucking in the intake gaskets slightly causing weird shit that seams random.
Premium Member
Unread postby YaBoyHalle » Fri Dec 05, 2014 11:16 am
ignition switch, if they were still used.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Fri Dec 05, 2014 1:05 pm
nah no vac leaks
yea all ford up until recent have ignition switches lol, nothing wrong with it
Unread postby red5.0fogger » Fri Dec 05, 2014 5:35 pm
Sounds so much like egr stuck open just a tad but I see they changed it. How about a loose crank sensor?
Premium Member
Unread postby decipha » Fri Dec 05, 2014 7:49 pm
nope
Unread postby ranga83 » Fri Dec 05, 2014 8:18 pm
im at a disadvantage here, I don't know what the engine bay looks like on all these cars haha
ranga83
Unread postby decipha » Fri Dec 05, 2014 9:10 pm
lol no different than any other
Unread postby decipha » Fri Dec 05, 2014 11:19 pm
I guess this one was a little more difficult than I thought it would be
The capacitor next to the coil was bad, it had residue of it guts visible on it
replaced it with a spare I had laying around and all was well! Not an issue since.
Unread postby red5.0fogger » Sat Dec 06, 2014 12:47 pm
This segment gives US a taste of what it's like to try and help with a car from long distance. Without sight ,sound ,smell. Not easy, decipha does a good job.
Premium Member
Unread postby YaBoyHalle » Sat Dec 06, 2014 2:17 pm
you're exactly right in that. i had no idea they had caps for this car.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Unread postby decipha » Sat Dec 06, 2014 4:02 pm
yeah they have little resonator capacitors that bolt down next to the coil packs, most people think its there to prevent radio interference but its actually there to help regulate the coil voltage, its a very small cap but that's exactly whats needed to prevent random misfires
Unread postby slimmons2009 » Fri Sep 25, 2015 7:27 am
Mike,
I know this is an old subject but would this still be an issue with after-market coils/ignition systems? Or better yet, should we keep the capacitor when using after-market coils/ ignition systems?
slimmons2009
Premium Member
Vehicle Information: 1989 Notch, 306, On3 76mm Turbo Kit, TW Heads, TF Stage 1 cam, 80lb injectors, TF Street Heat Intake, HPX-E MAF,
TF 75mm TB, Quarterhorse, 5 Speed, 3.73
Vehicle 2 Information: 2013 Ford F250, H&S Mini-Max with SPE Hot X tune, Downpipe back Flo-Pro exhaust, Cold air, 8" Pro Comp lift, 38's
Vehicle 3 Information: 2011 Chevrolet Suburban bone stock with a few cosmetic upgrades
Unread postby decipha » Fri Sep 25, 2015 7:50 am
yes the capacitors MUST be there
Unread postby slimmons2009 » Fri Sep 25, 2015 9:29 am
That could be an issue with mine. I notice a little miss at idle and was going to investigate next time home. Guess I will be adding a capacitor to the coil to see if this clears the issue. And you are saying to use a capacitor even with a MSD ignition system?
slimmons2009
Premium Member
Unread postby decipha » Fri Sep 25, 2015 10:19 am
with any, all coil packs need a resistor to buffer voltage drops/spikes
Return to Games & Recreation
