HARD CUT REV
Posted: 2021 Mar 10, 05:41
by therocks
Hi
possible to make an hard rev cut like omex rev limiter?
i know on this eec is an injection cut but how to make ignition cut?
thx
Re: HARD CUT REV
Posted: 2021 Mar 10, 06:43
anything is possible
just simply find the coil output code and disrupt it for your limiter. Thats what I did for the 2 step on the gufx ecus.
Re: HARD CUT REV
Posted: 2021 Mar 11, 17:06
by therocks
thanks, i see what you have done in gufx when i compare the code with and without 2 step i see what change in the OST8_11 and the sub routine added in 8 A000 , but the coil output code is not the same with the KRAF5.
do you have some pointers for find the coil output code on KRAF5?
thx
Re: HARD CUT REV
Posted: 2021 Mar 11, 17:22
find how the coil dwell is calculated and youll find the on/off timers you can then manipulate it from there
Re: HARD CUT REV
Posted: 2021 Mar 14, 08:03
by therocks
on/off timers are MINDLA & MINDLB?
thanks
