HARD CUT REV
Used on the 99-02 Zetecs and SPI's in the ford focus.
Specifically used for Bostig Conversions.
therocks
Vehicle Information: x3 1997/2000 PUMA 1.7 MUFF / TAPE / DUDE
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
MONDEO MK3 ST220 6BDB
MONDEO MK3 DURATEC25 1RRC
HARD CUT REV
Unread post by therocks »
Hi
possible to make an hard rev cut like omex rev limiter?
i know on this eec is an injection cut but how to make ignition cut?
thx
Re: HARD CUT REV
anything is possible
just simply find the coil output code and disrupt it for your limiter. Thats what I did for the 2 step on the gufx ecus.
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
Re: HARD CUT REV
thanks, i see what you have done in gufx when i compare the code with and without 2 step i see what change in the OST8_11 and the sub routine added in 8 A000 , but the coil output code is not the same with the KRAF5.
do you have some pointers for find the coil output code on KRAF5?
thx
Re: HARD CUT REV
find how the coil dwell is calculated and youll find the on/off timers you can then manipulate it from there
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
Re: HARD CUT REV
on/off timers are MINDLA & MINDLB?
thanks
