Pmas Maf Ext Range Sensor
waltnono
WH40
76mm Turbo
4r70W
wbo2-uego
Upgrading to extended range senor. If using same tube does maf transfer need to be adjusted?
Re: Pmas Maf Ext Range Sensor
yep its an entirely different maf
kick up the entire maf flow by 45% by multiplying by 1.45 and then go from there til you find the percentage difference between your maf now and the new maf.
