FC-V fan control
Posted: 2023 Aug 29, 10:40
by cj428mach
I'm working on a godzilla swap and the godzilla body harness has only an FC-V fan wire on the PCM thats located on Pin #4 of the PCM plug. The godzilla originally had a clutch fan that it was able to control with the PCM. Is there any way to make the PCM control an electric fan? I'm wondering if I could just wire up a Ford Fusion soft start fan controller that uses a PWM ground signal to control the fan, but I'm not sure what FC-V wire is putting out? Power? Ground?
Also on the transmission harness there is a Fan Speed sensor wire would that need to be hooked up to something to keep the PCM happy?
Is there a way to have the PCM control a relay to just engage an electric fan?
Re: FC-V fan control
Posted: 2023 Aug 29, 13:52
most just wire up a thermostatic switch like these
https://www.ebay.com/itm/264534820305?_ ... %3A2047675
Posted: 2023 Aug 29, 14:58
by cj428mach
That maybe the way to go, but I was hoping for something fancy controlled by the PCM. Some how Ford has electric fans in their 7.3 Godzilla control pack.
