pcm install EK01 EK02 in 04 lightning will it work
Can be used on all 2002-2003 harley trucks and lightnings.
mbsvt1
Vehicle Information: 1992 Ford Mustang 5.0 LX vert 5 speed summer edition
347 cid
Long tubs 2.5 full Exhaust
Comp Cams extreme energy 282
Unread post by mbsvt1 »
Hello, I am looking to get a 04 Lightning they said has a bad PCM (won't stay running)
My question is will a EK01 or EK02 work if I tune it with my QH? I have both of the pcm in my stock.
Thank you
MB
Re: pcm install EK01 EK02 in 04 lightning will it work
yep no problem
mbsvt1
347 cid
Ty
Slow94
Vehicle Information: 2004 ford lightning: built motor, built trans kenne bell 3.2, nitrous
Unread post by Slow94 »
mbsvt1 wrote: 2023 Aug 25, 11:40 Hello, I am looking to get a 04 Lightning they said has a bad PCM (won't stay running)
Thank you
MB
It will work, however it won't run your intercooler pump. I have an 04 lightning and put in the same ECU you listed and there is something different in the pinout where it won't run the pump. I just wired my pump to run fulltime but I'm sure it's easy enough to make it work like factory. Also if you ever want to get rid of one of those ECU's let me know.
mbsvt1
347 cid
Will do Thanks for that useful information. MB
