ECU RZASA Compatibility
Posted: 2023 Aug 18, 08:52
by p4ndiamond
Are these ECU's compatible with RZASA and marauder strats like MAV2 ? just a curiosity. i remember there was a hardware differences list . But i can't find it anymore. If so does anything need to be changed to have this code set work on 04 mustang GT (besides standard tuning changes )
Re: ECU RZASA Compatibility
Posted: 2023 Aug 18, 14:24
its on the homepage theres a search box where you type in the hardware code and itll tell you what its compatible with. click on supported ecus on the left side menu.
all 03/04 ford cars used the same class hardware so they can all run the same code. Luxury cars had variable speed fan and additional controls like alternator and starter relay outputs. Where as the mustang had dual fan outputs.
The harfware is missing in the ecu if that vehicle group didnt come with it so dual fans wont work on a grand marquis ecu running fbgi0. And theres no starter interrupt circuit for the mustang ecus to crank a marauder etc... just simple stuff like that.
Posted: 2023 Sep 03, 09:23
by p4ndiamond
awesome. Thanks i forget about that.
So if i use RZASA on the stock mustang computer what would i have to change there for proper function ?
I do like the strat a lot and would like to utilize it .
Posted: 2023 Sep 03, 21:55
