90mm PMAS range
Posted: 2023 Jul 03, 22:23
Just out of curiosity, what could cause MAF counts to be much higher than expected?
I have a hitachi 90mm stock replacement MAF, in the stock 03/04 cobra airbox. I'm getting 1000 AD counts at ~50.3 lbs/min. I'm pretty sure t's not a problem with injector slopes, it's definitely not making the power to peg the MAF (350ish WHP on a dynojet through a 5 speed), it's just reading high for the air it's passing.
k constant is 30, SARCHG is set to 281 CID. green Ford 42lb injectors, slopes directly from the reference files and seem to behave perfectly - seeing 0.58 DC at 27 MHz.
thanks in advance for any help
