ISCKAM2 updating even with UPDATM set to 255
odrapnew
Vehicle Information: 1989 Mustang 5.0 Coupe.
A9S ECU, Tweecer R/T w/ Binary Editor
TFS Heads, Stg. 1 Cam, Cobra intake, Novi2K blower (on standby for now).
Unread post by odrapnew »
So, I've been playing with manual idle control be keep running into an issue where ISCKAM2 keeps updating, even with UPDATM set to 255.
Looking at my logs, it's about 7 seconds between ISCKAM2 updates.
Any ideas why that's happening?
Anything else I can change to prevent updates?
Re: ISCKAM2 updating even with UPDATM set to 255
Unread post by red5.0fogger »
From the write up, It seems to me like it will still update the isckam. You double checked the write up and did everything in there?
odrapnew
I believe I set it all up per the writeup, but I'll double check.
And you might be right that it will still update, just take longer.
When I stated it updates every 7 seconds, that's after idling for a decent amount of time....I'm guessing after about 255 seconds. :)
yeah 255 doesn't disable it just makes it take much longer
odrapnew
Got it, thanks.
