Page 1 of 2
Rev limiter scalars having no effect
Posted: 2023 Jun 15, 22:01
by SOAB_465
1998 mustang GT. 2valve 4.6 with original wiring harness and ECU. I have set NLMTLO_1, ~NLMTHI_0 and ~NLMTNEUHI_0 all to 6600 to 7000, but the engine hits a fuel cut at 6050RPM. does it both in gear and in neutral.
Is there another rev limiter or has anyone else come across this situation?
Thanks,
Paul
Re: Rev limiter scalars having no effect
Posted: 2023 Jun 17, 12:14
by 034v
MNPIP8 to ZERO done yet?
11,250,000 / (1/2 # of cylinders × max rpm)
Or
11,250,000 / (4×7000)
Posted: 2023 Jun 18, 14:26
by SOAB_465
CRAI8 xdf doesn't have MNPIP8 as far as I can tell, I wonder if it's hidden or mislabeled
Posted: 2023 Jun 20, 12:36
FNRPM_LIM its the rev limiter function for torque modification
Posted: 2023 Jun 20, 13:41
by SOAB_465
oh ok, that one isn't identified in CRAI8
Posted: 2023 Jun 20, 15:26
just posted a new xdf has it in there for you
enjoy
Posted: 2023 Jun 20, 15:35
by SOAB_465
That's awesome, thank you so much!
Posted: 2023 Jun 20, 15:55
by SOAB_465
I see now how the soft limiter works, is it safer to use the NLMT scalars on a boosted application? Does FNRPM pull fuel or timing?
Posted: 2023 Jun 20, 17:15
either is safe no issues there
why are you intending on hitting the limiter?
the objective is to shift before you bang the limiter
Posted: 2023 Jun 20, 17:43
by SOAB_465
Ha ha I know that's the goal, but when it doesn't hook up in 1st things happen too quickly for me. I'm still getting used to driving it with the twin screw, and don't want to make an expensive mistake before i get good at it.
