May 12, 2023 TUNERPRO 5.00.9816 UPDATE
<edit>
DO NOT RECOMMEND UPDATING.
Here is the version I am currently running.
TunerPro_5_9513.zip
exe file to copy in to tunerpro folder
(515.79 KiB) Downloaded 980 times
SetupTunerProRT_v500_9513.zip
install application
(17.22 MiB) Downloaded 1280 times
p4ndiamond
Vehicle Information: 2004 Mercury Marauder DTR
1997 Mustang Cobra
1998 Mustang Cobra
2021 Mustang Eco Boost
1989 foxbody hatch
Re: May 12, 2023 TUNERPRO 5.00.9816 UPDATE
Unread post by p4ndiamond »
Got this update and now can't open logs on the RZASA strat . Not sure if related. i just back dated my install to older version and will retry again later.
yeah newer logs are created and opened differently
p4ndiamond
1997 Mustang Cobra
1998 Mustang Cobra
1989 foxbody hatch
interesting . Do i have to change any settings . When i complete a new Log with the new software it just errors out that it cant open it. Even the ones the new version creates itself. Do i have to make some ADX changes ?
No should be all good
i hadnt ran in to that yet as it seems to work well but i myself have reverted to the previous tunerpro for the time being
Unread post by bad86capri »
What changes were made to the new update?
enough to not do it. Highly recommend sticking with the older version for now.
5.00.9290.00 is what I'm using and recommend all else use for now as well.
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
- tuning with TunerProRT
PLX Wideband
GM 3bar MAP
Unread post by SOAB_465 »
Do you happen to remember what version you were using last year? I updated TPRT and seem to have removed my old installer, but now when I reverted to 5.00.9290.00 it says the CRAI8_230423 and CRAI8_220707 xdfs were both created with a newer version.
reposted my file at top of thread go snatch em and should be all good
Unread post by red5.0fogger »
I was tying to run 5.00.9769.00 and it sometimes has had connection problems I guess.
