HP tuners help
Posted: 2023 May 19, 09:38
by PedroV915
Currently working on an 07 Crown Victoria with HP tuners. Seeing if anybody is handy with it. Not stock has a few modifications
Edelbrock Victor jr intake manifold with mmr adapter and 1/2" spacer on plenum and throttle body bbk edual length shorties dual cat delete dual xpipe setup egr delete 340lph fuel pump.Have a stock file not sure if I can post it in HPt form or put it in .zip? Any help would be appreciated. Currently have codes for intake air pressure high cats of course and egr. Any direction in where I can start adjust would be appreciated
Re: HP tuners help
Posted: 2023 May 19, 11:27
None of those modifications will affect the stock tune from running it satisfactorily.
manifold will require imrc delete and a slew of changes with that and to make the stock file more performance oriented. That is far beyond the capabilities of hptuners. hptuners should never be used for any ford vehicles with more than just basic modifications and shouldnt be used on any fords other than mustangs. The software is physically unable to support it by the way its designed.
You need an sct handheld or a mongoose and pcmflash to tune it how it should be tuned.
Re: HP tuners help
Posted: 2023 May 19, 11:50
by PedroV915
Crown Victoria doesn't have imrc enabled I have a sct itsx to upload a sct tune as well
Re: HP tuners help
Posted: 2023 May 19, 15:21
ah yes its a 2v thats correct
you need to fix that inlet air temp code before you can do anything
Re: HP tuners help
Posted: 2023 May 19, 16:23
by PedroV915
It's a p0108 Manifold Absolute Pressure/Barometric Pressure is High. Never had the engine code before the shorties and the egr delete. Maybe the egr not being plugged in is causing it? Currently it's open headers with blocked off egr and solenoid not plugged in how can I post a log or. Sct file ?
Re: HP tuners help
Posted: 2023 May 20, 10:43
by PedroV915
Alright update p0108 engine code is due to the egr delete. Egr has a map sensor built in. Going to put it back on and that should clear it
