99 explorer cam sync gear compatibility
Posted: 2023 Apr 27, 20:19
by dleach1407
Is the stock gear compatible with aftermarket cams like the E303 or N41? I just picked up a new cam sync and crank sensor and want to make sure the gear is compatible with aftermarket cams. I made the mistake of using the wrong gear in another engine and dont want to make that mistake again.
Re: 99 explorer cam sync gear compatibility
Posted: 2023 Apr 28, 08:22
You should replace the gear every time you replace the cam unless you have a composite gear.
Bronze gear is your safest bet.
Posted: 2023 Apr 28, 10:02
by dleach1407
It's a brand new synchronizer.
Posted: 2023 Apr 28, 18:06
by dleach1407
I got my answer on the Corral....
