4.6 mod twinturbo recommended ecm
Pappacosworth
Vehicle Information: SIGNATURE
Ford Mustang Cobra -94. Ported M112 ratio 2.375:1, 4.6 Dohc, ported c-heads, TR3650, 3.55 IRS, ZYA2
Coretuning/Moates/HPTuners/Innovate/Tunernerd Knock Monitor/
Unread post by Pappacosworth »
2006 3 valve engine. Ported heads with big valves, solid cam sprockets. Street use with electric tb. Power estimate would be 1000-1200 hp. Would you recommend aftermarket ecu. I think it would be safer to have dual wideband controlled ecu. Turbo plumping would be simpler for map.
Re: 4.6 mod twinturbo recommended ecm
sounds good
