Page 1 of 2
Inferred Ambient ACT
Posted: 2023 Mar 01, 18:02
by Turbo4V
Curious if INFAMB_KAM is still active with KAMRF disabled. I've essentially always left KAMRF off, but I get tremendous heat soak of the ACT sensor after long idles and hot restarts. The ACT sensor is still in the Slot MAF. I see the INFAMB_KAM decrement down slightly lower than ambient as I would expect, while the ACT at times is 60-80 degrees above ambient (hot restarts may show 160+ on 75F day). The fueling goes way lean as a result of false high ACT reporting the air temps far higher than ambient until I get moving to pull in cooler air. Doesn't seem like the inferred ambient is really doing anything to combat false ACT temp readings. Maybe I'm just misunderstanding how the inferred ambient strategy works or what it was designed to do? Does it matter if KAMRF is disabled?
Re: Inferred Ambient ACT
Posted: 2023 Mar 01, 22:20
yes it is
why would you leave kamrf off?
inferred ambient temp does not correct the iat its not even remotely related
an act sensor cant read faulty unless the sensor is faulty, theres no such thing as false act temps.
it soubds like you need more startup enrichment
Posted: 2023 Mar 02, 08:21
by Turbo4V
The reason I keep KAMRF disabled is because when at idle for any amount of time leading to high ACT readings (not necessarily true high ambient) the KAMRF will climb up +20-30%. After shutdown and overnight cooling the next restart with true ACT matching ambient, the KAMRF is now driving lambse way rich until enough time passes for KAMRF to update and settle down to something reasonable again.
My opinion is that the ACT sensor is hotter than the air flowing past it during hot restarts for the first couple minutes. If the ACT reading was true then the actual air density would be less than ambient density and the calculated air density would be correct so fueling would be correct. But that isn't what happens. The fueling is dead on when ACT is reasonably close to ambient, but lambse climbs as ACT begins to stray from ambient. If ACT was truely what it was reporting then air density would be less and fueling would be calculated correctly.
I did have to add a lot to the startup enrichment for +200F and above to get it stay running for the first minute after hot restart.
Posted: 2023 Mar 02, 11:09
by PaulC-turbo5.0
Although I dont recall seeing the crazy iat's you are I dealt with similar fueling issues due to heat soak. I re-wrapped my hotside last winter and this time around also wrapped the headers, they were just heat painted previously. That change has seemed to help out alot as my fuel trims didnt move around nearly as much last summer.
Posted: 2023 Mar 02, 13:39
by red5.0fogger
With the kamrf turned on and idling how does she run? Maybe just let the kams do their thing. The air will be hotter in the piping during a long idle. Maybe it's legit.
Posted: 2023 Mar 02, 13:54
by Turbo4V
The problem with having the KAMRF enabled is once they reach +20-30% during hot idle or right after a hot restart is that the next morning those trims are added during cold start and warmup until the updates pull them back down to near zero. So it is way too rich for several minutes. Fueling is dead on when ACT is in agreement with true ambient air temps.
Posted: 2023 Mar 03, 07:11
by red5.0fogger
Startup fuel is coolant temp based no? So why would hot kamrf numbers be used on the next days cold start?
Posted: 2023 Mar 03, 08:26
by Turbo4V
Not sure. Good question for Decipha. But my understanding is that whatever KAMRF is already in memory is always going to be added on top of startup enrichment adding that extra % to lambse.
Posted: 2023 Mar 04, 12:05
kamrf is a multiplier on airmass which is basically a maf corrector
if the maf is wrong when hot itll be wrong by the same when cold
20-30% means something is wrong
you can set the act max temp to allow adaptives to update. You need to kick that down for now til you figure out whats going on.
If its adding that much fuel when hot idling then your either getting some kind of partial vapor lock from too low of fuel pressure or more likely your injector data is wrong.
Posted: 2023 Mar 04, 13:20
by Turbo4V
Thanks for the suggestion. I will go ahead and try turning adaptives back on and lower the max allowed ACT for update if I can find it.
The MAF error is essential zero when ACT and ambient agree within a few degrees. But once they diverge by more than +10 F degrees or so it sure seems like the MAF error starts walking up proportionally. Fuel injector data is scaled FRPP data for their injectors so it should be correct. It sure seems correct when ACT and ambient are in close agreement.
It could potentially have something to do with vapor lock, but fuel pressure monitor shows normal 44psid and since hot restarts fire right off I don't think it is the root of the matter. Especially since the dead lean condition is persistent for several minutes after hot restart until the ACT comes down somewhere close to ambient.
