Amperage Draw for 10 dead batteries?
Posted: 2021 Mar 02, 17:18
I'm thinking a 12v nominal car battery discharged down to 10.5 volts is going to take about 230-340ma minimum draw to charge if no load is placed on it. I have approx 10 batteries I'm going to be putting in a battery rack and tossing in the back of my work truck. I drive 2 hours each day so its plenty sufficient to maintain them. Using my worse case of 3.4 amps I'm assuming a 5 amp fuse should be more than sufficient.
I plan on using a spare trailer wiring connector I have so I can easily plug in the battery pack and let it trickle on my excursions. I figured a 5amp diode would be able to survive. Suppose we shall see.
Anyone have a more realistic number or done something like this before with any experiences?
Re: Amperage Draw for 10 dead batteries?
Posted: 2021 Mar 07, 10:32
well diode not needed my work truck - 2019 F-150 completely isolates the trailer circuit from the parking lamp circuit so it doesnt backfeed. I've had 9 batteries hooked for the past few days and all has been well.
Posted: 2021 Mar 08, 13:04
by wwhite
When I first read this post, I thought "WTF?"
I am assuming you have the 9 batteries hooked in parallel.
I am assuming all batteries are identical, same amp hours, etc.
In a perfect world, each battery would have the exact same voltage, same electrolyte, same age, and take the exact same charge
When a battery with a higher voltage is connected to a battery with a lower voltage, one battery will charge the other.
This process will continue, while draining each battery.
This 'auto-equalization' of each battery is what is going to cause you issues.
The results are unpredictable.
You may have created a 9-cell electro-hydrogen bomb in the back of your truck!
Posted: 2021 Mar 08, 13:36
by PaulC-turbo5.0
I am also curious as what the reason is behind wanting to do something like this, what is the need for 10 extra batteries? lol
Posted: 2021 Mar 08, 13:45
correct
no
these are all different
yes im aware of the nominal voltage
As long as they all get up over 12 volts when charged i.e. no dead batteries then I don't see any issues. Yeah a dead battery would kill the others no doubt.
lol nah no worries..
I have too many vehicles that I don't drive often enough so Instead of rotating charges every so often its easier to maintain them by having them get a little juice each day to keep them topped off. I calculated out 136 hrs of engine run time with the alternator giving them 13+ volts. I'm thinking that would be better than using a charger to charge them every other month or so.
These also act as my backup inverter power backup when the electricity goes out during hurricanes and such.
