Histogram LWFM
Posted: 2022 Nov 26, 11:59
by Vince_m_97
Is there a histogram in Tuner pro that can be used to populate the LWFM table. Or can I make one using TP_REL, RPM AND LOAD_FG.
Re: Histogram LWFM
Posted: 2022 Nov 26, 13:08
its already there
load is incorrect though its load error
the histogram populates the correction percentage
Re: Histogram LWFM
Posted: 2022 Nov 26, 15:04
by Vince_m_97
That would be the N_TP_TOTLDSTerr histogram?
Re: Histogram LWFM
Posted: 2022 Nov 26, 15:07
by Vince_m_97
And I multiply the values in the LWFM table by the ones in the histogram.
Forgive me but...
IM TRYIN!!
Re: Histogram LWFM
Posted: 2022 Nov 29, 12:48
that all sounds right but im not at my laptop to verify
but yes the totldst error that populates in the histogram is the correction for the inferred load table. You multiply the current value in the table by the correction the histogram gives you.
I also have a newer adx that kicks out the actual lwfm table to copy and paste values as well but hadnt released it.
My GUFX strat I created a failed load table and have a specifically labelled GUFX histogram at the bottom of the list for those specifically if anyone is reading this with a fox ecu.
Best bet is to post in your actual strategy group thread so theres no confusion instead of using the range for strategy specific questions.
Re: Histogram LWFM
Posted: 2022 Nov 29, 20:17
by Vince_m_97
Thanks you
