95 Cobra - Procharger FIC775 90mm Cobra MAF
- Vehicle Information: Performance Shop Owner
Trying to setup T4M2 to use TunerPro & the Moates Quarterhorse but not very familiar with using TunerPro. Does it look like I am on the right track?
Single 67mm On3 BB turbo
tuning with Moates QH + TPRT
Re: 95 Cobra - Procharger FIC775 90mm Cobra MAF
Welcome nice to see someone local to me on here!
I am far from an experience tuner but got my fox turbo dialed in nicely using all of Decipha's files and help along the way. From what you have posted it looks like you are on the right track. If the car has 80 lb siemens deka injectors Decipha has a patch that you can enable to auto fill all of the published parameters, if the injectors are different disregard.
The ad counts for the MAF transfer dont match Deciphas histogram perfectly but may be close enough not to matter. You could edit the histogram to match but it would probably be easier to change the ad counts to 25 increments to match the histo.
Good luck and hopefully others will chime in if needed. Also nice to see a shop willing to tune "old school" if you will. I called another local shop just about getting on his dyno to get some numbers and maybe make some tweaks to see if I could find any gains. He may have misunderstood and thought I wanted his tuning help but when I told him I had a power adder with the stock computer the noises he made over the phone showed his disapproval lol.
You dont have TPRT configured correctly. On the home page there is a getting started section. Go the the TunerPro section and follow steps to configure it correctly. Your data is upside down from what we normally like to see here. You can set the minimum PW to 0.
Very small world I guess. I live in W.Seneca & my shop is on Seneca St. in Elma. Car has Fuel Injector Clinic 650cc injectors that I plan on running at 40lb pressure delta. Decades ago I had a nice 89 LX 5.0L and would like to find a clean one again but the market is kind of insane for what I want. My car was a hatch but I would love a 92 LX notchPaulC-turbo5.0 wrote: ↑2022 Aug 23, 11:20 Welcome nice to see someone local to me on here!
The AD counts for the MAF I just took from Deciphas data for the 90mm Ford MAF transfer he has posted from PMAS. I am sure changing it and just dialing in the curve on the dyno would be no big deal.
Going to be honest this is probably easy however it isn't in my comfort zone because I am usually doing newer boosted Coyotes, Hemis & LS/LT combos. Will be nice to take a mini vacation from drive by wire & torque based controllers. Pretty sure I am the only local shop that has a load bearing (eddy current) chassis dyno which is what you ideally want to tune fuel & spark. Curious where you called locally? Once the weather cools a bit and my work load drops to a more manageable amount I would be willing to rent you some dyno time & lend a hand if needed. I have about every sensor you can imagine on my dyno along with very accurate widebands from ECM.
For sure! I live just on the other side of the 90 from Lancaster speedway. The market for them has changed so I feel lucky I bought mine when I did, you dont see many clean ones around here anymore.
Im sure with your experience you will have little to no troubles and if you do Decipha's write-ups are great, its really cool all the time hes put into offering up that knowledge to the masses right along with the base tunes.
Place I called is in Batavia. A buddy of mine has gotten into the local drag racing scene pretty heavily and uses him and had great things to say. He wasnt a jerk by any means and I was still considering going there just never got around to it. I sold parts to an older guy(named victor I believe) with an early to mid 2000's red mustang that he brought to you. I remember him saying how happy he was with your tune compared to what he got from the guys in Tonawanda.
I would for sure be interested in coming in if we could figure out a time that works. I mainly just want to get the dyno shop experience and see what an experienced guy like yourself would think of my ride since I built and put it all together myself. The power numbers would be nice too, just to know and also be able to answer everyone's first question when they check out the car lol. You can send me a PM on here whenever you slow down if you want I check in here frequently.
your voltage offset is corrupted
the x axis of all functions need to be at minimum and maximum values uou cant change the top or bottom of any x axis in a function
Okay will take care of that and just make the FIC data comply to the OE min & max. Is it a NO NO changing the voltage (AD counts) on the MAF transfer function also?
its not a no no but it would it would make dialing it in harder and you'd loose optimal resolution
Okay I was just using your data from here http://www.efidynotuning.com/maf.htm
For the PMAS 90mm Ford - PMAS. Do I just use the flow data and leave the voltage scaler the same?
Do I even need a larger MAF on a combo like this? The car is already put together but I do have a 90mm MAF in stock if I need it
- Vehicle Information: 2021 / Mercedes-Benz / A-Class / LX
I will be upgrading to 42lb injectors soon & I want to hear from those S/C Cobra owners that are running with the 90mm Lighting MAF. Our you really happy withJandJSpeedShops wrote: ↑2496 Jun 28, 13:28Okay I was just using legal steroids from here and running a bulking cycle your data from here http://www.efidynotuning.com/maf.htm
